D-Jetronic: Using My New CHT Rich / Lean Test Box, And it shows pretty much what I though I knew was wrong... |
pbanders |
Nov 4 2016, 06:58 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
Some of you have seen the recent posting about the CHT spacer that helps warm-up, and the discussion that followed. I proposed making a test box that would use the CHT to adjust the mixture to either rich or lean while running to see what was really happening. The idea of inserting a pot into the CHT circuit is as old as the hills when it comes to D-Jet, but this is the first time I've enabled both rich and lean adjustment, plus put in a test point so I can monitor the resistance of the CHT as I drive around.
I just did my first run, there will be more, but I have a few interesting results and observations already. First, there has been a lot of conjecture and theory about what's going on with the 914 D-Jet during warm-up and hot starting (where the car has sat for 5+ minutes after stopping). The conjecture for crappy warm-up was that the CHT heated up to quickly, leaning out the mixture and causing crummy idle. Hence, the spacer, a factory (VW) solution. Space the CHT above the head, slow the thermal conduction, and fool the ECU into thinking the engine is cooler and needs more fuel. Turns out it works pretty well, but doesn't fix the hot start problem. I conjectured that the spacer made the hot start problem worse, because the sensor cooled off faster than the head, and made the mixture too rich. I came up with a way to start the car (key off , 1/4 throttle open, key on, start) that seemed to verify this, as more air with more fuel worked. But, as we learn in science, experiment trumps theory. So, I went out with the box today, here's what I found. Warm-up with the spacer proceeds well. Resistance of the CHT starts at about 2200 ohms and drops to around 400 ohms in the first 5-10 minutes of driving (sort of a cool day here in Phoenix). The fun begins when you turn the key off. According to my theory, the CHT sitting away from the head cools off, and the resistance increases, causing a lean hot start condition. Not so, not at all. Key off the resistance of the CHT plummets, dropping from 400 ohms down to 100 ohms in just a few minutes. Why? Duh, there's no cooling air, the fact that it's sitting away from the head is irrelevant. When you try to restart, the CHT thinks the car is way hotter, and wants a leaner mixture, and it won't start for crap. The core of the engine is at nearly the same temperature it was before you turned it off after 5 minutes, it wants a much richer mixture. Enter the "rich" potentiometer knob. I can dial in exactly the same resistance I saw when I went key off. When I do that, the car starts right up. So, no, it's not too rich, it's too lean. I also played with the knob in a number of other idling situations. It was very easy to make a quick adjustment when the idle bogged from any loads (e.g. fresh air fan, heater blower, lights) to richen the mixture slightly, and the idle stabilized very well. I have to stop the car and turn the motor off to measure the CHT resistance, but I can monitor the voltage on the CHT continuously, and compare that to the SPICE model I did for the circuit years ago. I'll do that in the future. Oh, and I played with using the lean adjustment, but it was never needed. The 914 always wanted more fuel, more, more, more! Right now, I'd have to say that adding a 500 ohm series pot to the CHT that you can adjust from the driver's seat is pretty awesome. I know others have done this before and said the same thing, I'm saying, "me, too". I'll be experimenting with this setup through the week, will report more on what I find. |
TX914 |
Nov 5 2016, 08:36 AM
Alan-B Group: Members Posts: 167 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None |
That is totally excellent. Thanks for sharing your results. Couple of questions (if I had electrical skills marginally better than a chimp I could find out myself):
• You surmised that when engine is stopped the core of the engine remains about the same (temp) while the CHT sensor becomes hotter. Is this because heads are aluminum and soak in heat build-up? • Any idea how long it takes on restart for the CHT sensor to rid itself of heat build-up (i.e. return to normal)? Since you can measure voltage while running, is it possible to infer from your CTC voltage vs. resistance graph how long it takes? • I suppose ideally compensation would be removed gradually as CHT sensor returns to normal, although I don’t suppose a rich condition for too long would be harmful. • Given compensation will be manual, perhaps a light on the box would useful as a reminder to revert to normal operation. |
pbanders |
Nov 5 2016, 03:29 PM
That is totally excellent. Thanks for sharing your results. Couple of questions (if I had electrical skills marginally better than a chimp I could find out myself): • You surmised that when engine is stopped the core of the engine remains about the same (temp) while the CHT sensor becomes hotter. Is this because heads are aluminum and soak in heat build-up? • Any idea how long it takes on restart for the CHT sensor to rid itself of heat build-up (i.e. return to normal)? Since you can measure voltage while running, is it possible to infer from your CTC voltage vs. resistance graph how long it takes? • I suppose ideally compensation would be removed gradually as CHT sensor returns to normal, although I don’t suppose a rich condition for too long would be harmful. • Given compensation will be manual, perhaps a light on the box would useful as a reminder to revert to normal operation. HTH, Alan The heat soak happens because the cooling air supply is cut off to the sensor. When you're driving at a constant load for a long enough time, the sensor equilibrates at some temperature determined by the thermal conductivity of the head, the radiation from the head, and the temperature and flow rate of the engine cooling air. When you shut the car off, the sensor does NOT, as I stupidly thought, suddenly cool off more quickly, but instead it continues to heat up because of the lack of cooling air. I'm hoping to characterize from cold to hot to cold how long this process takes. It's a lot slower than you'd think. If I can infer it from the CTC voltage I will. The additional compensation provided by using a pot only is required briefly, under a minute from what I could tell. Could an automatic system be designed? Most likely, but it won't be me who is doing it, I'm not good enough at circuit design. |
stugray |
Nov 5 2016, 04:14 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
The heat soak happens because the cooling air supply is cut off to the sensor. When you're driving at a constant load for a long enough time, the sensor equilibrates at some temperature determined by the thermal conductivity of the head, the radiation from the head, and the temperature and flow rate of the engine cooling air. When you shut the car off, the sensor does NOT, as I stupidly thought, suddenly cool off more quickly, but instead it continues to heat up because of the lack of cooling air. (IMG:style_emoticons/default/agree.gif) In fact I can see in my datalogger exactly when I shut the engine off because the CHTs spike while the EGTs drop. I could even look to tell you how quickly it begins to drop again, but I rarely left the DL on for long after shutting down. I'm hoping to characterize from cold to hot to cold how long this process takes. It's a lot slower than you'd think. If I can infer it from the CTC voltage I will. The additional compensation provided by using a pot only is required briefly, under a minute from what I could tell. Could an automatic system be designed? Most likely, but it won't be me who is doing it, I'm not good enough at circuit design. There are commercial systems to "fool your ecu" even on cars as modern as my BRZ. One that comes to mind is "unichip". They just give the ECU altered data from MAP, MAF, IAT, AFR, etc to fool the ECU into making more power (operating outside predefined parameters). My datalogger in my race car is an Arduino based system monitor that measures multiple temperature and voltage inputs (EGTs, CHTs, AFR, RPM, Throt Pos, Oil Press, Oil Temp). To measure just 1X Cylinder Head temp (CHT) & 1X Intake Air temp (IAT), I could program a chip the size of your thumbnail to control a variable potentiometer based on a table lookup. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.jameco.com-10819-1478384056.1.jpg) You could update the tables over usb to tune it. To do it right would require 2X miniature thermocouple amplifier boards @$15ea It could read the two temps CHT & IAT and decide what temp to present to the ECU as a variable resistance output. If it could also read MAP, AFR & RPM, it could adjust the rich/lean bias in the ECU by moving that CHT input to the stock circuit. I can plug my cellphone into imy DL and read the temps all in real time: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1478384056.2.jpg) |
Lo-Fi Version | Time is now: 1st May 2024 - 09:52 PM |
