Taylors new project thanks to Wes, Rust, just not in the usual places. |
Mikey914 |
Nov 14 2016, 01:53 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Wes was nice enough to hook Taylor up with a roller project. He drove down to Mendocino to get it about 3 weeks ago. We finally have it in a place we can work on it and started the clean up.
The backstory is that Wes got it in Oakland where it had sat behind a rib joint for some time. Apparently, some rodents made a home in the air box. They also acquired a taste for ribs. It appears the brought a few back with them. They were there for some time, and urinated eating the bulkhead out. The hell hole and floorboards look good. The pan is intact and looks good. He has a bunch of work ahead of him, but it will get restored back to stock ivory white. Attached thumbnail(s) |
cary |
Dec 26 2017, 11:43 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
After a little more inspecting ..................
I found the left front sway bar mount is missing a nut and torn. (IMG:style_emoticons/default/mad.gif) Used my Tangerine backing plate to center it up and weld on an 8mm flange nut to put it back in business. Then it was time to take a look at the front trunk channel. I'll probably move this repair to a separate thread because I'll be using the 914 Rubber's weatherstripping channel repair strips. |
Lo-Fi Version | Time is now: 27th May 2024 - 10:40 AM |
