Taylors new project thanks to Wes, Rust, just not in the usual places. |
Mikey914 |
Nov 14 2016, 01:53 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Wes was nice enough to hook Taylor up with a roller project. He drove down to Mendocino to get it about 3 weeks ago. We finally have it in a place we can work on it and started the clean up.
The backstory is that Wes got it in Oakland where it had sat behind a rib joint for some time. Apparently, some rodents made a home in the air box. They also acquired a taste for ribs. It appears the brought a few back with them. They were there for some time, and urinated eating the bulkhead out. The hell hole and floorboards look good. The pan is intact and looks good. He has a bunch of work ahead of him, but it will get restored back to stock ivory white. Attached thumbnail(s) |
cary |
Dec 29 2017, 09:42 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Next was the tune up of the hinge support and dash tie in.
Yes, the blasting glass continues to fall out of the long ............... After close inspection I decide the floor/firewall/chassis tie in braces need new flanges rather than trying to fill in the damage done by the spot weld removal. Went to Rothsport today and stomp sheared some 1/2" 20ga strips. Then it was time to start the fitting of the replacement fuel tank/firewall lower portion. It's going to take some time determining the cut out. Nothing was left of original section. It came out in pieces. The lower section of the fender/fuel tank will be installed after the section above. |
Lo-Fi Version | Time is now: 18th May 2024 - 02:09 PM |
