Taylors new project thanks to Wes, Rust, just not in the usual places. |
Mikey914 |
Nov 14 2016, 01:53 AM
The rubber man Group: Members Posts: 12,653 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Wes was nice enough to hook Taylor up with a roller project. He drove down to Mendocino to get it about 3 weeks ago. We finally have it in a place we can work on it and started the clean up.
The backstory is that Wes got it in Oakland where it had sat behind a rib joint for some time. Apparently, some rodents made a home in the air box. They also acquired a taste for ribs. It appears the brought a few back with them. They were there for some time, and urinated eating the bulkhead out. The hell hole and floorboards look good. The pan is intact and looks good. He has a bunch of work ahead of him, but it will get restored back to stock ivory white. Attached thumbnail(s) |
cary |
Jun 30 2017, 10:27 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Back to work on Taylor's project.
1st. Cut off the nose ................ Pretty much junk ............. You can see the wrinkle on the right side. When time allows we'll trim some other pieces off. The seal channels are nice. #2. Off came the needed section. As Taylor is drilling out spot welds on the car tomorrow. I'll ponder how much we're going to use. #3. Drilled out the center tunnel so it can be saved in it entirety. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 04:00 PM |
