Taylors new project thanks to Wes, Rust, just not in the usual places. |
Mikey914 |
Nov 14 2016, 01:53 AM
The rubber man Group: Members Posts: 12,653 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Wes was nice enough to hook Taylor up with a roller project. He drove down to Mendocino to get it about 3 weeks ago. We finally have it in a place we can work on it and started the clean up.
The backstory is that Wes got it in Oakland where it had sat behind a rib joint for some time. Apparently, some rodents made a home in the air box. They also acquired a taste for ribs. It appears the brought a few back with them. They were there for some time, and urinated eating the bulkhead out. The hell hole and floorboards look good. The pan is intact and looks good. He has a bunch of work ahead of him, but it will get restored back to stock ivory white. Attached thumbnail(s) |
cary |
Sep 3 2017, 10:09 AM
Time to switch from coach to hired gun.
Cut out the destroyed section. (IMG:style_emoticons/default/sawzall-smiley.gif) It takes quite a bit of nip, tuck and cuts to get the patch piece fitted. You what it tight enough for a nice weld. But you need enough room to take it in out 100 times to get it trimmed up. (IMG:style_emoticons/default/sad.gif) In went the new section. After sending Super In Law home head down and back to work. I was bound and determined to get the replacement portion tack in. (IMG:style_emoticons/default/biggrin.gif) From inside the fender. Topside shot. Seam along the wall was a bit tough to fit. Back corner cut out was a little over-sized, but the copper backer took care of that. Looks like I cut it back far enough to get good weldable metal. I do have a few impurities coming out from between the layers on the shock mount. (IMG:style_emoticons/default/evilgrin.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 05:02 PM |
