Taylors new project thanks to Wes, Rust, just not in the usual places. |
Mikey914 |
Nov 14 2016, 01:53 AM
The rubber man Group: Members Posts: 12,653 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Wes was nice enough to hook Taylor up with a roller project. He drove down to Mendocino to get it about 3 weeks ago. We finally have it in a place we can work on it and started the clean up.
The backstory is that Wes got it in Oakland where it had sat behind a rib joint for some time. Apparently, some rodents made a home in the air box. They also acquired a taste for ribs. It appears the brought a few back with them. They were there for some time, and urinated eating the bulkhead out. The hell hole and floorboards look good. The pan is intact and looks good. He has a bunch of work ahead of him, but it will get restored back to stock ivory white. Attached thumbnail(s) |
cary |
Jan 6 2018, 09:15 AM
Friday didn't quite go as planned so I went back to work on Taylor's car.
Finished the stitching and got the front seam welded in. Didn't over finish the bottom. It will be under coated. The top side finished up real nice and its ready for the wall section. Then it was back to the oil canned section next to the fuel tank access hole. The little shrinking disk takes quite a long time to get the metal heated up. Or maybe its just cold outside. With the front attached I got about 80% of it out. On to the passenger floor seam ................. With the front tied down it allowed me to pound it down flat. As it flattened out I trimmed a couple more mms out between the 2 pcs as I went along. Saw blade width. I even retained the drain slot ............... 6 inches to go on the back side. I have a piece to trim down to replace the section that got scalped during cut out. Getting an early start. Want to get this section finished up. Plus waiting for a reply on a wood/metal upright band saw on Craigslist. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 05:54 PM |
