d-jet 1.7, turning over but not starting |
surfdogskier |
Nov 22 2016, 08:50 AM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
Hey guys, finally got back to my car. I switched out the ignition switch which was broken. Now my blinkers, wipers, lights, etc work great. However, I am still to getting the car to start. Turns over fine and I know my fuel pump is working and sending gas through the lines.
I am wondering if my cold start valve is gone bad. I plan on taking it off today. What should I expect to see or not see? I heard these do not go bad often but something just isn't working and that was my next step. What steps do you guys recommend? Thanks again |
Frankvw |
Nov 22 2016, 09:42 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Hi, since it is cranking and you have fuel....check for spark.
PS : you mention : "fuel pump is working and sending gas through the lines"...that does not mean your injectors are firing/sending fuel in, so check that as well. Keep us updated ! |
Lo-Fi Version | Time is now: 17th May 2024 - 06:27 AM |
