Could this work?, 2056 engine combo ?'s |
ottox914 |
Nov 23 2016, 02:07 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
So here's my long sad story. The turbo motor dies several yrs ago, due to a missed shift at lots of boost and rpm's. I bought a recently re-built motor from a forum member to replace it, thinking this was faster and easier than re-building the turbo motor. Lost a year to a new job, selling an house, buying a house, moving to a new state, bring my retired dad along and getting him re-set in a new environment. Put the re-built motor in this past summer. It kept blowing up. Pulled it and fixed it all summer. Kept the seller updated as to my problems with the "good" motor. Called the seller this fall, who graciously agreed to refund full purchase price.
So now I again have a motorless 914. Trying to figure out an N/A build that uses most of the parts in my shed to keep $$$ down. I have the pieces in my stash to build the following: 2 good cases to choose from, 2.0 crank and rods, some good iron cylinders to overbore to 96, (would need to buy some KB's to fill them) some heads that Len did that are 40 x 36, (about 75% I/E ratio) that he says will flow about 175 cfm at 50% lift. They have a 50.4cc chamber. So these, with some flat top KB's would yield about 10.5:1 with .040 deck. 2x valve springs, Len is comfortable with this head to 7k rpm if I would need to go there. I have the ITB's and SDS efi to run it all, and as the injectors were sized to support the turbo motor, I expect I have enough headroom to run some E85 "corn" fuel to handle the CR. Should also hold detonation at bay, and engine should run cooler on corn. Not a bad thing for aircooled motors. Kerry hunter exhaust to finish things off. The wild card is the cam. The cam I had in the turbo motor is still good, not damaged by the over rev. Its ground on a 110 center, has a lift of .500, and is a split duration of 276I/284E, with duration at .050 of 240/249. When researching cams for the turbo motor, seems lots of folks say a factory cam N/A is a pretty good starting point for a turbo cam. When I go to the Web Cam page for the 914, what I got is bigger than an 86, the "street" cam, but not as wild as 86a or 494. What think the collective? Will the flow of the head, small-ish intake valve, and big lift of the cam play well as a team? I expect to get alot of "its all in the combo" remarks, but with as much as is known about what I have to build with, and the cam being the big ?, looking for opinions from those more cam-educated than myself on options to use what I got or not. |
ottox914 |
Nov 26 2016, 04:48 PM
In searching around, seems lots of folks have done the 2056 with the factory EFI and a mild cam upgrade, and been well pleased with the results.
Can we hear from some of the carb'd guys on what their cam choices have been, and what they think about the final product? I expect carb motors will be closer to what my ITB motor could end up being. |
Lo-Fi Version | Time is now: 26th May 2024 - 03:17 PM |
