Left Side Ignition, converting your dash |
McMark |
Nov 25 2016, 11:52 AM
About a year ago I struck a deal with Pete at Restoration Design to start reproducing the 914-6 dash piece. I gave him a discount on a fuel injection system in trade for the die development costs. He finished these up awhile ago, and they're now available on his web site. But it wasn't until now that I had time to install one. It's a pretty easy process that I'll detail here.
Here's the repalcement piece from RD. I intended the design to be cut apart and not installed as one piece. The idea is that you can mark the lock section and cut it out. And then what you're left with is the new piece and a template to mark the location where the new piece goes. The switch 'bump' and the little notch at the bottom of the dash are the alignment markers. It's not idiot proof though, so measure twice and cut once. Marking where I want the cuts. Precision cutoff wheel work. (IMG:style_emoticons/default/sunglasses.gif) Template in place to mark dash for cutting. More precision surgery. (IMG:style_emoticons/default/av-943.gif) Replacement piece fits in the hole. I TIG welded it, but MIG works fine. Go slow, take brakes. Heat is the enemy. Grind and smooth to a no-filler needed finish. All in all, it took me almost exactly 2 hours to install the piece. It's lined up perfectly with the other holes and it's ready for install. I can do these for $200, send your dash to me and I'll convert it. This one isn't spoken for, but I'm saving first right of refusal for Rob (ConeDodger) since last I heard he wanted a left ignition. (IMG:style_emoticons/default/bye1.gif) |
SixerJ |
Dec 21 2016, 08:37 AM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
I'm seeing two ways, a no lock with what looks like stock /4 switches and one with 911 switches and locking. I take it the latter is correct...or are they both correct? Yep, Genuine six route would be the latter, lots of bits and $$ as even the 911 parts are no longer a low cost option. -4 route would be the dash frame mod, relocate ignition (no lock) and keep the -4 column etc - comparatively simple and much less $ than the full six route I'm doing the former as I have a genuine six, but it lost its column (and other bits) when she went racing & trying to reverse time Start with the frame mod while hunting for 911 parts, lower commitment but with future options? |
Lo-Fi Version | Time is now: 25th April 2024 - 04:47 PM |
