Left Side Ignition, converting your dash |
McMark |
Nov 25 2016, 11:52 AM
About a year ago I struck a deal with Pete at Restoration Design to start reproducing the 914-6 dash piece. I gave him a discount on a fuel injection system in trade for the die development costs. He finished these up awhile ago, and they're now available on his web site. But it wasn't until now that I had time to install one. It's a pretty easy process that I'll detail here.
Here's the repalcement piece from RD. I intended the design to be cut apart and not installed as one piece. The idea is that you can mark the lock section and cut it out. And then what you're left with is the new piece and a template to mark the location where the new piece goes. The switch 'bump' and the little notch at the bottom of the dash are the alignment markers. It's not idiot proof though, so measure twice and cut once. Marking where I want the cuts. Precision cutoff wheel work. (IMG:style_emoticons/default/sunglasses.gif) Template in place to mark dash for cutting. More precision surgery. (IMG:style_emoticons/default/av-943.gif) Replacement piece fits in the hole. I TIG welded it, but MIG works fine. Go slow, take brakes. Heat is the enemy. Grind and smooth to a no-filler needed finish. All in all, it took me almost exactly 2 hours to install the piece. It's lined up perfectly with the other holes and it's ready for install. I can do these for $200, send your dash to me and I'll convert it. This one isn't spoken for, but I'm saving first right of refusal for Rob (ConeDodger) since last I heard he wanted a left ignition. (IMG:style_emoticons/default/bye1.gif) |
rick 918-S |
Nov 28 2016, 05:31 AM
Hey nice rack! -Celette Group: Members Posts: 20,422 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Mark, there is a washer that goes on before the shear screws go in. I'll try to get a photo later. It sandwiches the dash tin between the switch and the washer.
I made one for a guy once. I used a electrical box cover for the material, a knockout punch and a pattern off an original part. |
McMark |
Nov 28 2016, 09:11 AM
Mark, there is a washer that goes on before the shear screws go in. I'll try to get a photo later. It sandwiches the dash tin between the switch and the washer. I made one for a guy once. I used a electrical box cover for the material, a knockout punch and a pattern off an original part. Yup. It was just for mockup. (IMG:style_emoticons/default/wink.gif) Just looked, is that plate not available anymore? Is the 914-6 one different than the 911? If I can get one, I can have them laser cut en masse. |
Harpo |
Jan 16 2017, 09:34 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Mark, there is a washer that goes on before the shear screws go in. I'll try to get a photo later. It sandwiches the dash tin between the switch and the washer. I made one for a guy once. I used a electrical box cover for the material, a knockout punch and a pattern off an original part. Yup. It was just for mockup. (IMG:style_emoticons/default/wink.gif) Just looked, is that plate not available anymore? Is the 914-6 one different than the 911? If I can get one, I can have them laser cut en masse. Hey Mark any luck with this reinforcement plate? Otherwise I will modify an old 911 to fit with marginal results. I made a crappy pattern of the inside of the 914-6 dash and transferred it to a 911 piece |
Lo-Fi Version | Time is now: 25th April 2024 - 04:57 PM |
