Left Side Ignition, converting your dash |
McMark |
Nov 25 2016, 11:52 AM
914 Freak! Group: Retired Admin Posts: 20,177 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
About a year ago I struck a deal with Pete at Restoration Design to start reproducing the 914-6 dash piece. I gave him a discount on a fuel injection system in trade for the die development costs. He finished these up awhile ago, and they're now available on his web site. But it wasn't until now that I had time to install one. It's a pretty easy process that I'll detail here.
Here's the repalcement piece from RD. I intended the design to be cut apart and not installed as one piece. The idea is that you can mark the lock section and cut it out. And then what you're left with is the new piece and a template to mark the location where the new piece goes. The switch 'bump' and the little notch at the bottom of the dash are the alignment markers. It's not idiot proof though, so measure twice and cut once. Marking where I want the cuts. Precision cutoff wheel work. (IMG:style_emoticons/default/sunglasses.gif) Template in place to mark dash for cutting. More precision surgery. (IMG:style_emoticons/default/av-943.gif) Replacement piece fits in the hole. I TIG welded it, but MIG works fine. Go slow, take brakes. Heat is the enemy. Grind and smooth to a no-filler needed finish. All in all, it took me almost exactly 2 hours to install the piece. It's lined up perfectly with the other holes and it's ready for install. I can do these for $200, send your dash to me and I'll convert it. This one isn't spoken for, but I'm saving first right of refusal for Rob (ConeDodger) since last I heard he wanted a left ignition. (IMG:style_emoticons/default/bye1.gif) |
Mark Henry |
Jan 21 2017, 06:54 PM
Just got a deal on a 69-73 column from my buddy who's sending me the ignition switch (IMG:style_emoticons/default/piratenanner.gif)
Only thing is the switch doesn't have keys, didn't someone say there's a trick to getting the tumbler out? |
mb911 |
Jan 22 2017, 07:29 AM
914 Guru Group: Members Posts: 6,748 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Just got a deal on a 69-73 column from my buddy who's sending me the ignition switch (IMG:style_emoticons/default/piratenanner.gif) Only thing is the switch doesn't have keys, didn't someone say there's a trick to getting the tumbler out? Yup just did it Mark on the one I got.. If you look just below the threaded portion for the bezel there is pin that needs to be removed. If your looking at the lock head on with the column lock pointing to the right it would be about the 2 o'clock position. I drilled a small drill right next to the pin and used a sharpened tungsten from my TIG machine to remove the pin.. It pops out easily once you get it to move. |
Lo-Fi Version | Time is now: 29th March 2024 - 04:27 AM |
