Late 2.0 air ports heads, what do I plug the ports with? |
rfinegan |
Nov 26 2016, 03:55 PM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I just picked up a late 2.0 l engine and need to plug the air port in the heads. What do I need? I'm not going to be pumping, i just want the blocked
A search shows just threaded a 10x1.0x50 bolt into it Best -Robert |
Krieger |
Nov 26 2016, 05:20 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Call Engine Builders Supply in Reno. They have threaded plugs. Same size as 911
DavidSweden |
Nov 26 2016, 05:28 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I just picked up a late 2.0 l engine and need to plug the air port in the heads. What do I need? I'm not going to be pumping, i just want the blocked A search shows just threaded a 10x1.0x50 bolt into it Best -Robert If you mean the holes for the smog injection, I used 1/8" NPT plugs. They worked fine for me |
Lo-Fi Version | Time is now: 17th May 2024 - 07:31 AM |
