Trying to rebuild my pedal cluster, rust fighting back >> got it apart |
Chris914n6 |
Nov 27 2016, 05:48 PM
Jackstands are my life. Group: Members Posts: 3,287 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I popped the roll pin out of the clutch arm. Soaked it, hammered it, stuck it in a vise and muscled it, no budge. What's the trick?
Nov 27 2016, 05:58 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Our mechanics always use heat to unstick things and lots of it.
BeatNavy |
Nov 27 2016, 06:00 PM
Certified Professional Scapegoat Group: Members Posts: 2,921 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
It was a royal PITA for me. I soaked it with PB. Then tried that acetone/ATF fluid mix. Lots of heat. BF Hammer. No dice. Finally after several days I think I had it in a vice with a drift the right size. Used the floor jack handle as my cheater bar and finally got it to budge. After that, it was just a matter of time. This one can really suck, no doubt about it. It was harder than the shift bar linkage pin I did last year, and I thought THAT was PITA (IMG:style_emoticons/default/hissyfit.gif)
gms |
Nov 27 2016, 06:24 PM
Advanced Member Group: Members Posts: 2,692 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
if you don't have a press try an air chisel and heat
Elliot Cannon |
Nov 27 2016, 06:51 PM
Or send it to bdstone914.
injunmort |
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
i am confused. did you get the roll pin out and now having trouble intsalling
it or have you been unable to remove it? |
Chris914n6 |
Nov 27 2016, 08:19 PM
porschetub |
Nov 27 2016, 08:21 PM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I popped the roll pin out of the clutch arm. Soaked it, hammered it, stuck it in a vise and muscled it, no budge. What's the trick? Are you punching the pin from the correct side,if I rememeber right theres one end and then the other,Elliot that's sounds like the sort of reply you would get on Pelican,no disrespect to Bruce but many can only afford DIY. Its not like we own cars that are worth that much ...sad really. My assembly was all pretty and painted up but little else found most bushes gone or very worn,replaced with bronze bushes all good. |
Chris914n6 |
Nov 27 2016, 08:44 PM
I can see the confusion now. I'm trying to get the arm off to do new bushings, clean and repaint and stuff.
Nothing against bdstone, I just like to do my own stuff. |
bdstone914 |
Nov 27 2016, 10:09 PM
bdstone914 Group: Members Posts: 4,496 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I popped the roll pin out of the clutch arm. Soaked it, hammered it, stuck it in a vise and muscled it, no budge. What's the trick? Yes heat. Heat it until the bushings catch fire and burn them out. If you hammered on the end of the shaft you will mushroom it and never get it out. Hammer the shaft back in by placing the clutch shaft end with the lower clutch arm over the spread vice jaws. Hit straight down just enough to get it to move. Now inspect the end to see if it is mushroomed. If so file or grind down the flare on the end. Then clamp the other end of the clutch shaft in the vice and using a large adjustable wrench twist the lower clutch shaft wist back and forth until you can get at least 1/4 turn of movement. Don't use to much force in twisting. I have twisted the hole shaft and stretched the round roll hole oval. If that is not clear I can take pictures tomorrow. I have had a few out of the couple hundred I have rebuild where I could not get the lower clutch to move. I then grind through the lower clutch arm with an angle grinder. If you have to do that I can supply a replacement part. Last resort send it to me and I will rebuild it. Bruce |
rjames |
Nov 27 2016, 11:22 PM
I'm made of metal Group: Members Posts: 3,876 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
When I rebuilt mine I had the same issue and ended up just taking it to a machine shop. They got it out in 10 minutes and didn't charge me anything.
bdstone914 |
Nov 28 2016, 12:04 AM
Here are some pics. Pound the shaft into the clutch arm with the vice jaws spread just wider than the shaft diameter. You only need to move it about MM. Grind down the flared end.
Clamp either end of the shaft on the vice and twist the other end with a long wrench. Work back and forth until it turns more easy. Clamp the shaft flange in the vise. Have a helper use two screw drivers to pry on the lower shaft while you twist the lower clutch flange. put the upper clutch pedal back in to have more leverage. Attached thumbnail(s) |
whitetwinturbo |
Nov 28 2016, 11:24 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
mb911 |
Nov 29 2016, 04:45 PM
914 Guru Group: Members Posts: 6,748 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Bruce what bushing kit brand do you recommend and where do you suggest buying them?
Rsjg911 |
Nov 29 2016, 05:53 PM
Member Group: Members Posts: 89 Joined: 13-June 16 From: Weston, Florida Member No.: 20,105 Region Association: South East States |
Sounds like rebuilding your cluster turned into a Cluster Fuch!
Good luck! (IMG:style_emoticons/default/drunk.gif) |
Chris H. |
Nov 29 2016, 07:38 PM
Senior Member Group: Members Posts: 4,024 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
That job that is rarely worth doing yourself. The brute force and heat required to get that &*(&^*ing thing apart is nuts. Top 10 on the "914 projects that suck" list. Send it to Bruce, he will send you a nice purty one back.
Nov 29 2016, 07:59 PM
That job that is rarely worth doing yourself. The brute force and heat required to get that &*(&^*ing thing apart is nuts. Top 10 on the "914 projects that suck" list. Send it to Bruce, he will send you a nice purty one back. (IMG:style_emoticons/default/agree.gif) 100% |
bdstone914 |
Nov 29 2016, 09:01 PM
To the OP: did you get it apart? did the pictures make sense?
Thanks for all the kind words. After doing a couple hundred you learn a few tricks. I like building them. Some I get apart in ten minutes. Some in an hour and the one in the picture never. I realize my service is not for everyone and do not mind helping with advice helping other rebuild theirs. I also do them for 911 up through 1989 including the G50 type sets. Bruce |
bdstone914 |
Nov 29 2016, 09:04 PM
Chris914n6 |
Nov 29 2016, 10:32 PM
To the OP: did you get it apart? did the pictures make sense? Thanks for all the kind words. After doing a couple hundred you learn a few tricks. I like building them. Some I get apart in ten minutes. Some in an hour and the one in the picture never. I realize my service is not for everyone and do not mind helping with advice helping other rebuild theirs. I also do them for 911 up through 1989 including the G50 type sets. Bruce Thanks. Pics helped alot. I didn't think of pushing it in to break the bond. I'm hoping to get to do car stuff tomorrow. Mine is not nearly that rusty so I'm optimistic. Is someone making replacement springs? Mine is missing, though I think I'll be engineering a helper spring for the big 9" clutch. |
Lo-Fi Version | Time is now: 28th March 2024 - 08:22 PM |
