Trying to rebuild my pedal cluster, rust fighting back >> got it apart |
Chris914n6 |
Nov 27 2016, 05:48 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I popped the roll pin out of the clutch arm. Soaked it, hammered it, stuck it in a vise and muscled it, no budge. What's the trick?
porschetub |
Nov 27 2016, 08:21 PM
Advanced Member Group: Members Posts: 4,698 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I popped the roll pin out of the clutch arm. Soaked it, hammered it, stuck it in a vise and muscled it, no budge. What's the trick? Are you punching the pin from the correct side,if I rememeber right theres one end and then the other,Elliot that's sounds like the sort of reply you would get on Pelican,no disrespect to Bruce but many can only afford DIY. Its not like we own cars that are worth that much ...sad really. My assembly was all pretty and painted up but little else found most bushes gone or very worn,replaced with bronze bushes all good. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:05 PM |
