Trying to rebuild my pedal cluster, rust fighting back >> got it apart |
Chris914n6 |
Nov 27 2016, 05:48 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I popped the roll pin out of the clutch arm. Soaked it, hammered it, stuck it in a vise and muscled it, no budge. What's the trick?
bdstone914 |
Nov 28 2016, 12:04 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Here are some pics. Pound the shaft into the clutch arm with the vice jaws spread just wider than the shaft diameter. You only need to move it about MM. Grind down the flared end.
Clamp either end of the shaft on the vice and twist the other end with a long wrench. Work back and forth until it turns more easy. Clamp the shaft flange in the vise. Have a helper use two screw drivers to pry on the lower shaft while you twist the lower clutch flange. put the upper clutch pedal back in to have more leverage. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 02:57 PM |
