Trying to rebuild my pedal cluster, rust fighting back >> got it apart |
Chris914n6 |
Mar 28 2017, 12:26 AM
Jackstands are my life. Group: Members Posts: 3,302 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Round 2. FIGHT!
Melted the bushings out no problem. Mounted in press, cooked the end, got it to pop to about middle of the pin hole. Mounted in vice, filed the lip, cooked end again, can't get it to twist. I've got it soaking overnight. Luckily this is an extra one. |
Chris914n6 |
Aug 25 2017, 10:31 PM
Trying to get everything that needs to go thru the new sand blast cabinet done so I can get it moved from the driveway, so gave it another shot. Guess it soaked long enough or it just needed to be under 100f outside (IMG:style_emoticons/default/laugh.gif)
Now I can finally put it in the pile to powder coat (IMG:style_emoticons/default/piratenanner.gif) |
bdstone914 |
Aug 26 2017, 09:01 AM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Trying to get everything that needs to go thru the new sand blast cabinet done so I can get it moved from the driveway, so gave it another shot. Guess it soaked long enough or it just needed to be under 100f outside (IMG:style_emoticons/default/laugh.gif) Now I can finally put it in the pile to powder coat (IMG:style_emoticons/default/piratenanner.gif) The clutch shaft looks like it is some what under size from the rust eating it. You can build them up with JB Weld and smooth it out. As it it might make for extra wobble in the pedals. I am going to soon be making new clutch shafts with ball bearings to replace the bushings which wear through even if the bronze ones are used. Half of the ones I see are like or worse then yours. |
worn |
Aug 26 2017, 09:22 AM
can't remember Group: Members Posts: 3,143 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Lo-Fi Version | Time is now: 19th April 2024 - 08:56 AM |
