FS: 1966 Porsche 912 Vintage Race Car |
greggearhead |
Nov 28 2016, 02:50 PM
Newbie Group: Members Posts: 35 Joined: 19-March 11 From: Colorado Springs, CO Member No.: 12,836 Region Association: None |
This is a wonderful 912. It has been a race car for many years now, owned and campaigned in PCA and Rocky Mountain Vintage Racing by an ex-Navy pilot who has (and does) own several other Porsches. With his hot rod 1968 911 being almost done, he realizes he really doesn't need to keep the 912 for HP DE's and track days anymore, so it is up for sale. It was built and refined to be a reliable car – not a hand grenade. On tight tracks it can still give many 911s a serious run for the money. With the theme of reliability, the engine was built with Weber 40 IDF Carbs, header with custom 'stinger' Supertrapp muffler. It runs 3 oil coolers – the stock one in the doghouse, an additional one in the engine bay, and another behind the drivers headlight. This can be run for an enduro in 100 degree heat with no problems. Turn the key, start it up and go – can easily be driven on the street – and is street registered currently! It would need the headlights reconnected and a little wiring done for real street duty, but nothing difficult. The transmission is a close ratio 912 box that has a slightly lower 5th gear to make it about 500rpm closer to 4th for track use. Koni shocks, sway bars, etc. This was built years ago, and the interior was kept in place for the most part, unlike most race cars that rip everything out. To return the interior to stock would require some front seats and floor mats and that's all. The paint and cosmetics are very good, even moreso when you consider it's a race car that's been used. It doesn't have nor has ever had any rust issues. It had fiberglass front and rear bumpers and rear decklid with 911R hinges. It weighs 1925lbs, with all glass windows – original Sekurit except for the windshield, so it could be MUCH lighter with some lexan and more fiberglass! Want a vintage SWB Porsche to take a Sunday morning blast through the canyons, or to a Cars and Coffee event, and then autocross, or do a track day or all of the above, and not spend six figures? Not many options out there. To find a car as clean as this, and then build it would obviously cost more, and then you would still need to iron out the wrinkles. This one is ready to go. $45,000 or best offer Chassis set up for racing by German Motorcraft in 1991 Car maintained by German Motorcraft since built for racing Car painted “Wimbledon White” in 1998 Blue vinyl stripes in 2003 Vinyl numbers in 2005 Registered Vintage Racer, RMVR number 480, E Production Registered for street with collectible plates Chassis and Suspension Fiberglass front bumper Fiberglass rear bumper with stock exhaust cutout Fiberglass engine lid Light-weight, aluminum engine lid hinges Billet aluminum hood pin (blue) for engine lid Removable driver and passenger windows and frames Front 21mm Weltmeister torsion bar Rear Porsche turbo 26mm torsion bar Front sway bar – Weltmeister 19mm Rear sway bar – factory 18mm Tow hook mounted to the front suspension and marked by red vinyl arrow/“tow” Koni adjustable Classic shocks, (4) set @ full stiffness 6” x 15” Cookie Cutter wheels (5) 205/50ZR15 GF Goodrich, g-Force R1 (4) Front end: -1.5 degree camber, 1/16 inch toe-in, 5.5 degree caster Rear end: -2.5 degree camber, 1/16 inch toe-in 8-gal JAZ fuel cell – special mount locating cell forward Pierburg rotary fuel pump, relocated forward, adjacent to fuel cell with filters both sides Bosch 030 fuel filter (2) on both sides of fuel pump, located forward next to fuel cell ATE 19mm dual brake master cylinder Stainless steel brake lines Titanium-backed brake pads (front) Turbo tie-rod ends Lightened solid engine mount New, light-weight horn grills (2) Competition roll bar with padding Floor-mounted Kidde fire extinguisher Grant GT 13” steering wheel g-Force 5-point harness belts (2 sets), manufactured June 2013 Corbeau Forza racing seats (2), adjustable, blue Extra Gauges installed – VDO oil pressure, oil temperature, and voltmeter Electrical and Ignition System Battery cut-off switch and cable Battery relocated forward on aluminum framing Bosch voltage regulator Bosch 050 ignition distributor Beru ignition wire set Crane XR700 ignition system, plus coil with electronic points Transmission and Clutch Transmission rebuilt 2006 New 5th gear ratio – V Aluminum 911S racing clutch and pressure plate Lightened flywheel and new seal New clutch cable Engine 1968 Core - #4094548, rebuilt 2011 86mm big bore NPR pistons and cylinders ¾ race cam, #86 grind Cylinder heads reconditioned with 1mm milling to raise compression 3-angle valves with new valve guides Competition lifters and springs Intake ports matched to intake manifolds Reciprocating parts balanced to 1/10 gm 4” aluminum power pulley New 16-blade fan External 5” x 13” radiator oil cooler mounted underneath engine grill 19-row 12AN 235mm oil cooler mounted behind open left headlight bowl Aluminum, light weight oil cooler in doghouse Bosch SR17X starter installed 2013 Racing tuned exhaust header Header-wrapped exhaust with stainless steel safety wire Stainless 4” Super Trapp exhaust Mechanical fuel pump removed and sealed Weber 40mm IDF carbs with manifolds and velocity stacks, rebuilt 2011 30mm venturies Main jets set @ 140-142 EMPI tall K&N air cleaners with billet hats New accelerator pull rod with metal encased rod link Powder-coated tin wear (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366216.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366217.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366217.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366217.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366217.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366217.6.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366217.7.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366218.8.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366218.9.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366218.10.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366218.11.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366218.12.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366219.13.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366219.14.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366219.15.jpg) |
greggearhead |
Nov 28 2016, 02:54 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366481.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366481.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366482.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366482.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366482.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366482.6.jpg) |
greggearhead |
Nov 28 2016, 02:55 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366523.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366523.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366523.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366523.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366523.5.jpg) |
greggearhead |
Nov 28 2016, 02:56 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366593.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366593.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366593.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366594.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1480366594.5.jpg) |
greggearhead |
Jan 16 2017, 11:55 AM
Still available
Lo-Fi Version | Time is now: 7th May 2024 - 01:06 AM |
