| tsvo |
Nov 29 2016, 07:22 AM
Member ![]() ![]() Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest
I am looking fsome help. I have a 1973 1.7L. I have replaced the points and wires as well as general tune up. It starts fine and seems to idle OK. However after 30 - 45 Min of running it starts to bog down. The car loses power, idle drops then backfires. The car gets a quick power surge at the time of backfiring. THe cycle then repeats. I let the car cool down for a little while and it usually goes away.
Any sugestions? |
| 76-914 |
Nov 29 2016, 10:12 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,879 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Did you replace the condenser also. Have you checked the coil's resistance? (IMG:style_emoticons/default/beerchug.gif)
| BeatNavy |
Nov 29 2016, 10:54 AM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Fuel injection or carbs? Initial thought is you're running way too rich or your timing is over-advanced. If FI, there are a couple of potential causes including blown MPS, fuel pressure too high, wonky CHT, etc. When you replaced the points, did you set dwell and timing? You need to adjust timing after changing or adjusting points...
If it is FI you may want to start getting familiar with this site: http://members.rennlist.com/pbanders/djetparts.htm |
| tsvo |
Nov 29 2016, 12:38 PM
Fuel injection or carbs? Initial thought is you're running way too rich or your timing is over-advanced. If FI, there are a couple of potential causes including blown MPS, fuel pressure too high, wonky CHT, etc. When you replaced the points, did you set dwell and timing? You need to adjust timing after changing or adjusting points... If it is FI you may want to start getting familiar with this site: http://members.rennlist.com/pbanders/djetparts.htm Thanks, it is an FI. I did set the timing, but perhaps I need to recheck it. Any other thoughts are appreciated. |
| tsvo |
Nov 29 2016, 12:39 PM
Did you replace the condenser also. Have you checked the coil's resistance? (IMG:style_emoticons/default/beerchug.gif) I did not do the condenser. I will check that as well. |
| rmital |
Nov 29 2016, 01:17 PM
Northeast optimist ![]() ![]() ![]() Group: Members Posts: 1,955 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
.... If FI, there are a couple of potential causes including blown MPS, fuel pressure too high, wonky CHT, solid advise...over the last 10 years of 914ing, the above was a good start and most of the time, the cause(s). money's on the MPS of course, the most expensive solution (IMG:style_emoticons/default/dry.gif) |
| IronHillRestorations |
Nov 29 2016, 05:28 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,929 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Check the MPS, CHT, and the distributor.
I worked on a car that had a similar problem, when it got hot the advance plate in the distributor wouldn't move freely. |
| BeatNavy |
Nov 29 2016, 06:40 PM
I worked on a car that had a similar problem, when it got hot the advance plate in the distributor wouldn't move freely. Good point, Perry. A good dizzy cleaning is also a worthy idea. The old grease gets sticky and dirty over the years. Relevant thread: http://www.914world.com/bbs2/index.php?sho...232335&st=0. Dizzy cleaning starts around post #36. Rich would approve. |
| tsvo |
Nov 30 2016, 06:47 AM
.... If FI, there are a couple of potential causes including blown MPS, fuel pressure too high, wonky CHT, solid advise...over the last 10 years of 914ing, the above was a good start and most of the time, the cause(s). money's on the MPS of course, the most expensive solution (IMG:style_emoticons/default/dry.gif) THank you, I will give it a try |
| BeatNavy |
Nov 30 2016, 06:58 AM
Be methodical and follow the directions on that link I gave you for identifying the possible causes and eliminating them one by one through testing. You can do it, and you'll learn a lot about how to maintain it going forward. D-Jet is a pretty cool system, given its age, but if it hasn't been maintained something, or some things, will go wrong. If you have questions, let us know. Lots of good FI knowledge here on the World.
| Ansbacher |
Nov 30 2016, 11:23 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Had similar problem and turned out to be bad coil. Try a known good coil. Even if your existing coil checks out good cold, it might be bad when hot. I wasted a lot of time and money before I zeroed in on the coil. Good luck.
Ansbacher |
| tsvo |
Nov 30 2016, 02:08 PM
| tsvo |
Nov 30 2016, 02:09 PM
Had similar problem and turned out to be bad coil. Try a known good coil. Even if your existing coil checks out good cold, it might be bad when hot. I wasted a lot of time and money before I zeroed in on the coil. Good luck. Ansbacher Thank you, I will give it a try. |
| tsvo |
Nov 30 2016, 02:10 PM
Be methodical and follow the directions on that link I gave you for identifying the possible causes and eliminating them one by one through testing. You can do it, and you'll learn a lot about how to maintain it going forward. D-Jet is a pretty cool system, given its age, but if it hasn't been maintained something, or some things, will go wrong. If you have questions, let us know. Lots of good FI knowledge here on the World. Thank you again |
Lo-Fi Version | Time is now: 28th April 2026 - 07:29 PM |
