| rgalla9146 |
Nov 30 2016, 04:37 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,006 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Is it possible to remove the tunnel shift rod from an original 6 with the engine in the car ?
Converting to side shift. |
| IronHillRestorations |
Nov 30 2016, 04:41 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,958 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
IIRC, yes
| gms |
Nov 30 2016, 04:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,761 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest
Don't be afraid to destroy the front rod while removing because it is the same as the -4 so there are a bunch of them out there.
| rgalla9146 |
Nov 30 2016, 06:58 PM
Don't be afraid to destroy the front rod while removing because it is the same as the -4 so there are a bunch of them out there. ![]() Good point Glenn. But if that's necessary to remove it, it seems unlikely that the side shifter piece can just be slid in. Is the cup on a early tunnel piece removable ? ....roll pin ? |
Lo-Fi Version | Time is now: 1st November 2026 - 07:02 PM |
