1974 1.8L not holding a charge, Causes other than alternator |
Robnxious |
Dec 3 2016, 02:40 PM
RobnxiousOne Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
I have tried digging in on this a bit on here searching, and have seen posts saying "make sure it's the alternator before replacing". Here is what I have found so far. When the battery has a full charge, the volt reading is 12.75, and when it's running, it's about 13.5 (I remember reading on here last night that the running voltage should be about 14.5 IIRC). Which tells me it SHOULD be the alternator (that and the fact that if I run it with lights on at night, it needs charging when I get home). Also, my battery charger has an alternator check function and it said it was bad.
But, I also did the old shade tree mechanic trick of disconnecting the negative battery connection when the car was running, and it didn't miss a beat, still idled strong. I do have an alternator that I bought (yeah I know, didn't see the threads saying "make sure it's the alternator before buying" until after I had ordered it), but seeing how this is a PITA job the first time, I am hoping I can get my new baby up and running easily. Any help is appreciated, and thanks in advance |
larryM |
Dec 3 2016, 03:24 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
When the battery has a full charge, the volt reading is 12.75, and when it's running, it's about 13.5 (I remember reading on here last night that the running voltage should be about 14.5 IIRC). if I run it with lights on at night, it needs charging when I get home). I also did the old shade tree mechanic trick of disconnecting the negative battery connection when the car was running, normal alternator output is 13.8-14.2v - that would generally be tested "off-idle" normal alternator output how to test alternator on-car alternator test what is your volt reading when running with lights on? - likely less if it won't recharge the batt BAD idea to disconnect alternator with engine running see alternator woes - google |
Robnxious |
Dec 3 2016, 03:50 PM
normal alternator output how to test alternator on-car alternator test what is your volt reading when running with lights on? - likely less if it won't recharge the batt BAD idea to disconnect alternator with engine running see alternator woes - google [/quote] Thanks for your quick response. To answer your question, I went out and tested it. *Started it up, was at 13.3 running. *Turned on Lights, went to 12.75, and then started dropping rapidly. After less than 1 minute, it was down to 12.4 *Turned lights off, popped right back to 13.5 instantly and stayed there *Decided to test it with lights off, but turning the radio on. Stayed at 13.5 It looks like I have a simple solution here (just don't drive at night! (IMG:style_emoticons/default/smile.gif) ) Seriously though, I have ZERO time in working on these, and am not a trained mechanic, nor have I done any major projects on cars except for replacing items, but to me it seems that if I am running the radio, the power should drop if the alternator is not running, or after it dropped w/ the lights on, there should have been a slight drop when they were turned off, not an increase. I do have someone up here who does fantastic work and is a board member (Ron Kain of IPB Autosport, who did the inspection on it and who I had told that the alternator was bad, so it's not a mechanic who diagnosed it, it was me) but what's the fun of owning one of these if you aren't willing to wrench on it yourself? |
Lo-Fi Version | Time is now: 16th May 2024 - 09:39 PM |
