1974 1.8L not holding a charge, Causes other than alternator |
Robnxious |
Dec 3 2016, 02:40 PM
RobnxiousOne Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
I have tried digging in on this a bit on here searching, and have seen posts saying "make sure it's the alternator before replacing". Here is what I have found so far. When the battery has a full charge, the volt reading is 12.75, and when it's running, it's about 13.5 (I remember reading on here last night that the running voltage should be about 14.5 IIRC). Which tells me it SHOULD be the alternator (that and the fact that if I run it with lights on at night, it needs charging when I get home). Also, my battery charger has an alternator check function and it said it was bad.
But, I also did the old shade tree mechanic trick of disconnecting the negative battery connection when the car was running, and it didn't miss a beat, still idled strong. I do have an alternator that I bought (yeah I know, didn't see the threads saying "make sure it's the alternator before buying" until after I had ordered it), but seeing how this is a PITA job the first time, I am hoping I can get my new baby up and running easily. Any help is appreciated, and thanks in advance |
Frankvw |
Dec 3 2016, 04:17 PM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Could this not just be a bad battery? Not charging properly and using up the power when in use... Have your battery tested to rule this out. The battery places can test this pretty easy and most of the time as a free service...
Robnxious |
Dec 3 2016, 04:51 PM
Could this not just be a bad battery? Not charging properly and using up the power when in use... Have your battery tested to rule this out. The battery places can test this pretty easy and most of the time as a free service... Brand New battery too, which leads me to believe it had had a problem starting before and they just thought the battery was bad and replaced it. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:07 AM |
