1974 1.8L not holding a charge, Causes other than alternator |
Robnxious |
Dec 3 2016, 02:40 PM
RobnxiousOne Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
I have tried digging in on this a bit on here searching, and have seen posts saying "make sure it's the alternator before replacing". Here is what I have found so far. When the battery has a full charge, the volt reading is 12.75, and when it's running, it's about 13.5 (I remember reading on here last night that the running voltage should be about 14.5 IIRC). Which tells me it SHOULD be the alternator (that and the fact that if I run it with lights on at night, it needs charging when I get home). Also, my battery charger has an alternator check function and it said it was bad.
But, I also did the old shade tree mechanic trick of disconnecting the negative battery connection when the car was running, and it didn't miss a beat, still idled strong. I do have an alternator that I bought (yeah I know, didn't see the threads saying "make sure it's the alternator before buying" until after I had ordered it), but seeing how this is a PITA job the first time, I am hoping I can get my new baby up and running easily. Any help is appreciated, and thanks in advance |
ottox914 |
Dec 4 2016, 04:50 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
I'd agree with checking all grounds, battery, trans strap, the multi-lug ground on the engine, by the relay board, and load test the battery- not just a check for voltage with a meter. Made that mistake once- checked with a meter and had great voltage at the battery, but when load tested, the battery was no good. Wasted a fair bit of time looking for the answer when the problem was an easy one to fix, and was right in front of me.
Lo-Fi Version | Time is now: 17th May 2024 - 04:06 PM |
