Removing section of the wiring loom |
JFG |
Dec 4 2016, 01:43 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
As I'm fitting twin 40 IDF's I have no need for the missing fi system including the extra wiring that would go to the relay board in the engine bay.
Is there a straightforward way to remove the no longer needed section of loom, either by rerouting bits that may be needed elsewhere or simply removing altogether? 1974 2.0 |
porschetub |
Dec 4 2016, 02:35 PM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Theres a 4 pin plug on the relay board pull that out with associated wiring,thats that gone ,then proceed to the tech article section on here and jumper an earth off the relay board so you can run your low pressure pump through the existing FI relay,this is the best and only way to go.
Good luck (IMG:style_emoticons/default/beer.gif) |
JFG |
Dec 4 2016, 05:03 PM
There was no relay board in the engine compartment when i bought the car. All i have is the wiring on the main loom with the multi pin plug on the end.
Dec 4 2016, 06:18 PM
Resident German Group: Admin Posts: 41,581 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
There was no relay board in the engine compartment when i bought the car. All i have is the wiring on the main loom with the multi pin plug on the end. You'll need the *relay* board. Also, voltage regulator anyone? http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.php |
bdstone914 |
Dec 4 2016, 06:53 PM
bdstone914 Group: Members Posts: 4,496 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
There was no relay board in the engine compartment when i bought the car. All i have is the wiring on the main loom with the multi pin plug on the end. I have tested relay boards and voltage regulators. PM me for details. If I can get them in a padded envelope the shipping will be about $26. I would want $65 for a relay board, relays, and voltage regulator. |
IronHillRestorations |
Dec 4 2016, 08:38 PM
I. I. R. C. Group: Members Posts: 6,707 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You need the board, voltage regulator, and some of the relays, as well as an engine wiring harness. Bruce's offer is a very fair deal.
bdstone914 |
Dec 4 2016, 08:51 PM
porschetub |
Dec 5 2016, 01:06 AM
There was no relay board in the engine compartment when i bought the car. All i have is the wiring on the main loom with the multi pin plug on the end. Wow that changes the game.....best to research before then we would know (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) ,so much info out there and on here,Bruces offer is very generous go for it. Best to research your carb install as theres many wrong ways and a few right ways,if not you will be disappointed ,good luck. |
JFG |
Dec 5 2016, 11:08 AM
So it would appear i need to do some reinstatement work that had at some point been removed.
A little digging around and i found a diagram showing how to jump the relay board to allow the use of the existing original fuel pump wires ( which i'll run up to the front where the new pump is going be be fitted) and make use of the voltage regulator to avoid having to wire in a custom installation. Thanks for the help, Bruce as per my pm i'll be in touch shortly to arrange this and some other bits. If it wasn't for this forum i'd be (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/ar15.gif) |
Lo-Fi Version | Time is now: 28th March 2024 - 05:11 PM |
