question about fittings on original 6 oil tank, oil return fitting |
gereed75 |
Dec 5 2016, 10:05 AM
Senior Member Group: Members Posts: 1,247 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Regarding the oil return line (from the engine scavenge line). The line/hose screws onto a fitting. Does the fitting for this line screw into female threads on the oil tank??
I can see the 32mm hex head on this fitting, but I do not want to put a wrench on it and find that it is welded in and damage the tank. The tank is still in the car. I had it out last year for a paint/refurbish but do not remember exactly the arrangement at that fitting. I would prefer not to have to remove the tank. Thanks |
gereed75 |
Dec 5 2016, 04:09 PM
yep, I was able to do some work this afternoon and found that that fitting is a welded in nipple with a retention nut that helps hold the tank in the car.
I am ordering fittings for an oil cooler set up. Any one know the thread size on that nipple?? I am thinking 26 x 1.25 Thanks |
mb911 |
Dec 5 2016, 04:56 PM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
yep, I was able to do some work this afternoon and found that that fitting is a welded in nipple with a retention nut that helps hold the tank in the car. I am ordering fittings for an oil cooler set up. Any one know the thread size on that nipple?? I am thinking 26 x 1.25 Thanks How does it hold the tank in the car? I have never seen that on any of the 6 tanks I have ever seen. The 8mm studs are the only thing that holds them in the car.. |
mskala |
Dec 5 2016, 05:11 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
yep, I was able to do some work this afternoon and found that that fitting is a welded in nipple with a retention nut that helps hold the tank in the car. I am ordering fittings for an oil cooler set up. Any one know the thread size on that nipple?? I am thinking 26 x 1.25 Thanks How does it hold the tank in the car? I have never seen that on any of the 6 tanks I have ever seen. The 8mm studs are the only thing that holds them in the car.. The bottom fitting that goes into the engine bay is longer than you would think is necessary and has a very thin nut that pulls it against the wall. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:56 AM |
