fuel gauge sender, Bench testing |
80cap |
Dec 5 2016, 01:46 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Before I install my fuel tank is there a way to bench test the fuel level sending unit?
Thanks Brian |
Dave_Darling |
Jan 25 2017, 10:29 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The warning light contacts are on the same float as the gauge sender stuff, so it is unlikely that the float is getting stuck.
It could be that there is a short or problem in the resistance wire inside the sender, or it could be that the gauge is wonky. We tell people to always trust the light over the needle on the gauge. --DD |
HansJan |
Jan 25 2017, 10:52 PM
Member Group: Members Posts: 394 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
The warning light contacts are on the same float as the gauge sender stuff, so it is unlikely that the float is getting stuck. It could be that there is a short or problem in the resistance wire inside the sender, or it could be that the gauge is wonky. We tell people to always trust the light over the needle on the gauge. --DD Thanks Dave, I will start looking for a new/used gauge. Br, Hans Jan |
Dave_Darling |
Jan 26 2017, 02:23 PM
Lo-Fi Version | Time is now: 4th May 2024 - 11:52 PM |
