fuel gauge sender, Bench testing |
80cap |
Dec 5 2016, 01:46 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Before I install my fuel tank is there a way to bench test the fuel level sending unit?
Thanks Brian |
Retroracer |
Apr 16 2021, 04:50 PM
Senior Member Group: Members Posts: 609 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
Neil - so it does sound like a sender issue. Presumably you tried shorting the sender terminal to GND on the gauge to make sure you get "FULL" indicated? 4 ohms or so on the sender sounds OK within error limits, I'd just make sure that 1) the float is not getting snagged, 2) the wires/contacts are clean and 3) and you measure 4ohms or less consistently every time the float is at the top....
- Tony PS. I have a similar qualification to your son. Agreed: It does come in handy sometimes...! (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 03:25 PM |
