> fuel gauge sender, Bench testing
80cap
post Dec 5 2016, 01:46 PM
Post #21
Before I install my fuel tank is there a way to bench test the fuel level sending unit?
Thanks Brian
80cap   fuel gauge sender   Dec 5 2016, 01:46 PM
Dave_Darling   There should be three (possibly four) electrical c...   Dec 5 2016, 02:18 PM
80cap   Thanks Dave! Well like most things so far on m...   Dec 5 2016, 03:07 PM
914Bryan   Does anyone have pictures of this?   Dec 6 2016, 10:03 AM
jim_hoyland   :agree: Just went through this. The inside of the...   Dec 6 2016, 09:49 PM
Hans Jan   Just ran out of gas this evening. The reserve ligh...   Jan 25 2017, 09:59 PM
Dave_Darling   The warning light contacts are on the same float a...   Jan 25 2017, 10:29 PM
Hans Jan   The warning light contacts are on the same float ...   Jan 25 2017, 10:52 PM
bdstone914   The warning light contacts are on the same float...   Jan 26 2017, 09:42 AM
seatosummit   [quote name='Hans Jan' post='2448102' date='Jan 2...   Jul 20 2021, 10:55 PM
Dave_Darling   I will start looking for a new/used gauge. I su...   Jan 26 2017, 02:23 PM
fixer34   The warning light contacts are on the same float ...   Feb 12 2017, 02:14 PM
Hans Jan   Have not yet figured out how to read the resistanc...   Jan 26 2017, 06:51 PM
Hans Jan   See pic   Jan 26 2017, 06:51 PM
Dave_Darling   One of the three pins is ground, one is the signal...   Jan 26 2017, 10:50 PM
Hans Jan   After removing I find the following readings: Upsi...   Jan 27 2017, 03:10 PM
Dave_Darling   We had similar trouble when we bought the wife...   Feb 12 2017, 09:15 PM
914Sixer   Take the sending unit and let it soak in a some la...   Feb 12 2017, 09:57 PM
forrestkhaag   For what it is worth, I had to open my sender tube...   Feb 13 2017, 11:52 AM
Costa05   For what it is worth, I had to open my sender tub...   Nov 30 2020, 11:46 PM
Red76   The real thin wires on the outside edges of the fl...   Nov 3 2017, 02:11 PM
neilbardsley   I'm having a problem with my fuel sender/gauge...   Apr 13 2021, 01:39 PM
Retroracer   So that would point to either wiring or gauge bein...   Apr 13 2021, 02:25 PM
neilbardsley   So that would point to either wiring or gauge bei...   Apr 14 2021, 12:50 AM
Cairo94507   I just replaced my fuel sender. It was sticking a...   Apr 14 2021, 07:17 AM
neilbardsley   Ok. It's not the wiring. 1 ohms resistance o...   Apr 16 2021, 01:21 PM
euro911   Here's a good thread on testing and refurbishi...   Apr 16 2021, 02:07 PM
neilbardsley   Here's a good thread on testing and refurbish...   Apr 16 2021, 02:51 PM
Retroracer   Neil - so it does sound like a sender issue. Pres...   Apr 16 2021, 04:50 PM
neilbardsley   Thank you. Yes connecting directly to ground move...   Apr 16 2021, 11:53 PM
- Lo-Fi Version Time is now: 30th October 2026 - 02:56 PM
