Fuel injector voltage, Correct reading? |
timofly |
Dec 5 2016, 03:31 PM
Member Group: Members Posts: 164 Joined: 21-February 09 From: VA Member No.: 10,082 Region Association: MidAtlantic Region |
My 2.0 with stock fuel injection has a consistent missing at idle and all engine speeds. At idle, disconnecting the wire to the #1 fuel injector makes no difference, but disconnecting any other injector wire makes problem much worse and eventually stalls the engine.
The voltage reading from the #1 injector input plug varies from .19 to .28 volts at idle. That doesn't seem like much, but what should it be? (I didn't test another cylinder because I ran out of time to fool with it today.) Plugs are new and valves have been adjusted. Seems pretty clear that the problem is at #1 cylinder. |
reharvey |
Dec 5 2016, 07:56 PM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
The injectors operate at 3volts. Got that info from a Bosch D-jet manual. Ray
Lo-Fi Version | Time is now: 19th May 2024 - 03:59 AM |
