Fuel injector voltage, Correct reading? |
timofly |
Dec 5 2016, 03:31 PM
Member Group: Members Posts: 164 Joined: 21-February 09 From: VA Member No.: 10,082 Region Association: MidAtlantic Region |
My 2.0 with stock fuel injection has a consistent missing at idle and all engine speeds. At idle, disconnecting the wire to the #1 fuel injector makes no difference, but disconnecting any other injector wire makes problem much worse and eventually stalls the engine.
The voltage reading from the #1 injector input plug varies from .19 to .28 volts at idle. That doesn't seem like much, but what should it be? (I didn't test another cylinder because I ran out of time to fool with it today.) Plugs are new and valves have been adjusted. Seems pretty clear that the problem is at #1 cylinder. |
Spoke |
Dec 5 2016, 09:01 PM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
You can use a voltmeter if you integrate the pulse width over the period from one pulse to another. If you assume the pulse width is 1/10th of the period, then the average dc voltage measured would be 1/10th of the pulse voltage or .28x10=2.8v.
Best to check the other injector voltages. You could Swap injectors and see if the failure follows the injector or is the connector. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:48 AM |
