Fuel injector voltage, Correct reading? |
timofly |
Dec 5 2016, 03:31 PM
Member Group: Members Posts: 164 Joined: 21-February 09 From: VA Member No.: 10,082 Region Association: MidAtlantic Region |
My 2.0 with stock fuel injection has a consistent missing at idle and all engine speeds. At idle, disconnecting the wire to the #1 fuel injector makes no difference, but disconnecting any other injector wire makes problem much worse and eventually stalls the engine.
The voltage reading from the #1 injector input plug varies from .19 to .28 volts at idle. That doesn't seem like much, but what should it be? (I didn't test another cylinder because I ran out of time to fool with it today.) Plugs are new and valves have been adjusted. Seems pretty clear that the problem is at #1 cylinder. |
Spoke |
Dec 5 2016, 09:01 PM
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
You can use a voltmeter if you integrate the pulse width over the period from one pulse to another. If you assume the pulse width is 1/10th of the period, then the average dc voltage measured would be 1/10th of the pulse voltage or .28x10=2.8v.
Best to check the other injector voltages. You could Swap injectors and see if the failure follows the injector or is the connector. |
timofly |
Dec 8 2016, 08:16 PM
You can use a voltmeter if you integrate the pulse width over the period from one pulse to another. If you assume the pulse width is 1/10th of the period, then the average dc voltage measured would be 1/10th of the pulse voltage or .28x10=2.8v. Best to check the other injector voltages. You could Swap injectors and see if the failure follows the injector or is the connector. The failure follows the injector. Looking for replacement but local guy says $310 for one. I have four old ones that have been in a bag since I hauled the car out of a junkyard in 2006. I've tried two so far, and it's definitely better but still not right. |
Lo-Fi Version | Time is now: 28th May 2024 - 05:28 AM |
