Fuel injector voltage, Correct reading? |
timofly |
Dec 5 2016, 03:31 PM
Member Group: Members Posts: 164 Joined: 21-February 09 From: VA Member No.: 10,082 Region Association: MidAtlantic Region |
My 2.0 with stock fuel injection has a consistent missing at idle and all engine speeds. At idle, disconnecting the wire to the #1 fuel injector makes no difference, but disconnecting any other injector wire makes problem much worse and eventually stalls the engine.
The voltage reading from the #1 injector input plug varies from .19 to .28 volts at idle. That doesn't seem like much, but what should it be? (I didn't test another cylinder because I ran out of time to fool with it today.) Plugs are new and valves have been adjusted. Seems pretty clear that the problem is at #1 cylinder. |
Frankvw |
Dec 9 2016, 02:54 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Hi Timofly, you guys have Mr.Injector (*) in USA, I read good stories about them, only 17,50 dollars per injector...I wish we had that service/price over here.... just drop all 4 there plus 2 from your spare ones to have good spares as well.
(*)Of course there are many similair services/companies, but I just picked one that I see sometimes mentioned on forums. |
timofly |
Dec 9 2016, 10:38 AM
Hi Timofly, you guys have Mr.Injector (*) in USA, I read good stories about them, only 17,50 dollars per injector...I wish we had that service/price over here.... just drop all 4 there plus 2 from your spare ones to have good spares as well. (*)Of course there are many similair services/companies, but I just picked one that I see sometimes mentioned on forums. Frank, thanks. I have already sent them a note. Good tip though. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:59 AM |
