Found 914/6 Value Help Please |
Karguy12 |
Dec 8 2016, 10:04 PM
Newbie Group: Members Posts: 10 Joined: 8-December 16 From: Florida Member No.: 20,656 Region Association: None |
I am no Porsche expert although I have owned a few over the years. Ran across a 914 in a warehouse that is supposedly a 914/6. It has a 914/6 VIN stamped into the front right apron that looks factory (914043xXXX) The engine numbers match, trans numbers match and it has all of the 914/6 details that I could find like five bolt Fuchs, correct gauges, ignition, wiring harness, engine mounts, oil cooler, rear valance, etc. But the owner says he does not think it is a real 914/6 car. It has been in the warehouse for over 30 years and needs restoration but it is a very solid and straight car.
Engine is out as is the trans. The rear fuchs are a little wider than the fronts. The owner is asking me to make him an offer. So what I need to know is a. What is this car worth if it has ALL of the 914/6 stuff and it is NOT a real car?, and b. What would it be worth in this condition if it WAS a real car? Attached image(s) |
GeorgeRud |
Dec 9 2016, 05:22 PM
It does have the appropriate bracket for a -6 throttle cable on the transmission. Show a photo of the other side of the transmission to determine if it's an original -6 transmission or from a -4. However, like mine, it may have been converted to a side shifting transmission.
If the engine has the original large plastic air cleaner, it will not fit with the rain tray on the engine lid. |
Karguy12 |
Dec 9 2016, 05:51 PM
It does have the appropriate bracket for a -6 throttle cable on the transmission. Show a photo of the other side of the transmission to determine if it's an original -6 transmission or from a -4. However, like mine, it may have been converted to a side shifting transmission. If the engine has the original large plastic air cleaner, it will not fit with the rain tray on the engine lid. I am wondering if the car may have had a rear clip installed. I will check for evidence of repair there and other engine mounts next time I am over there. |
Lo-Fi Version | Time is now: 17th May 2024 - 11:54 PM |
