Found 914/6 Value Help Please |
Karguy12 |
Dec 8 2016, 10:04 PM
Newbie Group: Members Posts: 10 Joined: 8-December 16 From: Florida Member No.: 20,656 Region Association: None |
I am no Porsche expert although I have owned a few over the years. Ran across a 914 in a warehouse that is supposedly a 914/6. It has a 914/6 VIN stamped into the front right apron that looks factory (914043xXXX) The engine numbers match, trans numbers match and it has all of the 914/6 details that I could find like five bolt Fuchs, correct gauges, ignition, wiring harness, engine mounts, oil cooler, rear valance, etc. But the owner says he does not think it is a real 914/6 car. It has been in the warehouse for over 30 years and needs restoration but it is a very solid and straight car.
Engine is out as is the trans. The rear fuchs are a little wider than the fronts. The owner is asking me to make him an offer. So what I need to know is a. What is this car worth if it has ALL of the 914/6 stuff and it is NOT a real car?, and b. What would it be worth in this condition if it WAS a real car? Attached image(s) |
toolguy |
Dec 9 2016, 06:17 PM
Senior Member Group: Members Posts: 1,268 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
914-6 transmission have a number on the bottom fin that starts 750xxxx.
The xxxx will be real close to the Karman number stamped in the center of the rear trunk. That number starts 13xxxx |
Mike Fitton |
Dec 9 2016, 08:16 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
914-6 transmission have a number on the bottom fin that starts 750xxxx. The xxxx will be real close to the Karman number stamped in the center of the rear trunk. That number starts 13xxxx The Karman number in the rear trunk should match the number in the drivers side door jam. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:56 PM |
