Found 914/6 Value Help Please |
Karguy12 |
Dec 9 2016, 03:41 PM
Newbie Group: Members Posts: 10 Joined: 8-December 16 From: Florida Member No.: 20,656 Region Association: None |
I was able to get to see the parts stash for the car stored at a different location. Here are the engine and trans numbers. The trans looks restamped to me, but I am not expert. Font looks smaller than all others I have seen on Porsche transmissions. The trans did have the side shift pieces though and was supposed to be the one that came out of the car. It was converted to accept a larger clutch. Seat belts did NOT have retractors, passenger seat was non-adjustable. Gauges were out of the dash and in a box but looked correct for the 914/6. Airbox was there, they could not find the heat exchangers there. I am going back on Monday to take a closer look at the body.
I am not yet convinced. Attached image(s) |
gereed75 |
Dec 9 2016, 03:54 PM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
That is a 6 case type number. Not sure about the tranny stampings but the six did not come originally with a side shift although the original tail shift could have been converted.
Look at all the people following this thread (IMG:style_emoticons/default/w00t.gif) Lots of people interested in that engine serial number I am sure!! Good luck |
Karguy12 |
Dec 9 2016, 04:34 PM
That is a 6 case type number. Not sure about the tranny stampings but the six did not come originally with a side shift although the original tail shift could have been converted. Look at all the people following this thread (IMG:style_emoticons/default/w00t.gif) Lots of people interested in that engine serial number I am sure!! Good luck I have given my word that I will not release any numbers from this car. It has always been my position that that information is not mine to give like someone else's social security number or a hot girls phone number. I have appreciated that nobody has asked. The Engine number codes out to be a correct early USA Engine code for a 1970 914/6. The VIN to the car does NOT appear in any registry, so if you were hoping this might be your engine, sorry, not likely as it has been sitting in this warehouse for about 30 years. If anyone has a specific VIN for their car and want to ask I will give you a yes or no answer. On the side shift, thing, I misspoke and it is the bracketry for the throttle linkage from what I was told. Attached image(s) |
GeorgeRud |
Dec 9 2016, 05:22 PM
It does have the appropriate bracket for a -6 throttle cable on the transmission. Show a photo of the other side of the transmission to determine if it's an original -6 transmission or from a -4. However, like mine, it may have been converted to a side shifting transmission.
If the engine has the original large plastic air cleaner, it will not fit with the rain tray on the engine lid. |
Karguy12 |
Dec 9 2016, 05:51 PM
It does have the appropriate bracket for a -6 throttle cable on the transmission. Show a photo of the other side of the transmission to determine if it's an original -6 transmission or from a -4. However, like mine, it may have been converted to a side shifting transmission. If the engine has the original large plastic air cleaner, it will not fit with the rain tray on the engine lid. I am wondering if the car may have had a rear clip installed. I will check for evidence of repair there and other engine mounts next time I am over there. |
toolguy |
Dec 9 2016, 06:17 PM
914-6 transmission have a number on the bottom fin that starts 750xxxx.
The xxxx will be real close to the Karman number stamped in the center of the rear trunk. That number starts 13xxxx |
sixnotfour |
Dec 9 2016, 07:14 PM
914 Wizard Group: Members Posts: 10,418 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
and the trams ear is broke off
Karguy12 |
Dec 9 2016, 07:23 PM
carr914 |
Dec 9 2016, 07:48 PM
Racer from Birth Group: Members Posts: 118,356 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I see that it has a 914-4 engine lid drip pan. I'm not sure where you are in Florida, but Steve & I are in Tampa. Not trying to brag, but I would say that we have a Expert Opinion on 914-6s. We are willing to help without undermining any deal you might have. I might even know of the car! |
Karguy12 |
Dec 9 2016, 08:07 PM
Can anyone tell me what a 914/6 engine and trans may be worth needing rebuild and assembly?? Has heads, carbs, intakes, virtually everything.
Porschef |
Dec 9 2016, 08:13 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Very simply, knowledge is power, take T.C. up on his offer. I don't know him, but he's been around here a little while, enough so to probably trust implicitly... (IMG:style_emoticons/default/rolleyes.gif)
It could be a great deal, so is the education that may come along with it. (IMG:style_emoticons/default/smile.gif) |
Mike Fitton |
Dec 9 2016, 08:16 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
914-6 transmission have a number on the bottom fin that starts 750xxxx. The xxxx will be real close to the Karman number stamped in the center of the rear trunk. That number starts 13xxxx The Karman number in the rear trunk should match the number in the drivers side door jam. |
Dec 9 2016, 10:04 PM
Can anyone tell me what a 914/6 engine and trans may be worth needing rebuild and assembly?? Has heads, carbs, intakes, virtually everything. Not much--EXCEPT to someone with the 914-6 that it came out of. (Worth somewhere in between to someone with a 914-6 wanting an engine/trans at least of the correct type.) The 914-6 motor was basically a 1969 911T motor, AKA the wimpiest 911 motor ever produced. And a rebuild on it is nearly as expensive as a rebuild on a much higher-powered and better-regarded engine, so demand for them is relatively low. --DD |
toolguy |
Dec 9 2016, 11:18 PM
QUOTE The Karman number in the rear trunk should match the number in the drivers side door jam. Not necessarily. . The Karman tag on my original Six has no number stamped. . only the 2 digit paint code. |
Mikey914 |
Dec 9 2016, 11:30 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Soundd like youve hit the jackpot. As long as rust isnr too bad. You can spend 10k ( a rebuild) on an engine pretty easily. Work backwards to determine your value. 80k ish on a nice sorted car, 25k on paint snd motor if no real issues. Plan on anoter 5k for fudge, easily will put you at 40k. If you can get a better deal great. But the real question is are you in the ballpark?
porschetub |
Dec 10 2016, 03:23 AM
If the owner does not think it is a real six let him put a number on what he thinks it is worth. Might be a a lot less than what they go for. As Andy said it need a much closer look. Minor detail but it has a rain tray an 6' did not have one. Could be a swapped lid. Why is the engine and trans out? Engine turn over? That lid wouldn't close on a factory six air cleaner for starters,all about real numbers now (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/idea.gif) ,appears they might be there ??? Yea those whimpy six's ...really ,way better engine than the best stock 2 litre 4 ever was,tell me wrong Dave,sounds like a very random statement. |
Dec 10 2016, 07:15 AM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Can anyone tell me what a 914/6 engine and trans may be worth needing rebuild and assembly?? Has heads, carbs, intakes, virtually everything. Not much--EXCEPT to someone with the 914-6 that it came out of. (Worth somewhere in between to someone with a 914-6 wanting an engine/trans at least of the correct type.) The 914-6 motor was basically a 1969 911T motor, AKA the wimpiest 911 motor ever produced. And a rebuild on it is nearly as expensive as a rebuild on a much higher-powered and better-regarded engine, so demand for them is relatively low. --DD About $8-10k. That's with all the parts you described. Based off what I've gotten for the same parts. Demand for a 911t engine might be lower than the later engines but there is still a demand. Just go on earlySreg. There is still good money moving around for these early engines. |
Karguy12 |
Dec 10 2016, 08:21 AM
QUOTE About $8-10k. That's with all the parts you described. Based off what I've gotten for the same parts. Demand for a 911t engine might be lower than the later engines but there is still a demand. Just go on earlySreg. There is still good money moving around for these early engines. So based on this, if the car is NOT real, I've got about $10,000 in 914/6 parts (engine trans and suspension), and maybe $2,000-$4,000 in a parts car with the wheels? So around $12,000 conservatively? Another possibility is that it is a rear clipped car fixed from a rear end collision years ago. (that could be another explanation for the broken trans mounting arm) If that is the case, and there is a real 914/6 front clip, and a 914/4 rear clip with all of the 914/6 running gear, what does that make this frankenstein car worth? I will be able to inspect the body up on jacks next week. |
Dec 10 2016, 08:35 AM
QUOTE About $8-10k. That's with all the parts you described. Based off what I've gotten for the same parts. Demand for a 911t engine might be lower than the later engines but there is still a demand. Just go on earlySreg. There is still good money moving around for these early engines. So based on this, if the car is NOT real, I've got about $10,000 in 914/6 parts (engine trans and suspension), and maybe $2,000-$4,000 in a parts car with the wheels? So around $12,000 conservatively? Another possibility is that it is a rear clipped car fixed from a rear end collision years ago. (that could be another explanation for the broken trans mounting arm) If that is the case, and there is a real 914/6 front clip, and a 914/4 rear clip with all of the 914/6 running gear, what does that make this frankenstein car worth? I will be able to inspect the body up on jacks next week. There's a lot of pricey parts in a 914-6 besides the engine and trans. |
bretth |
Dec 10 2016, 08:43 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Another thing the car should have is the throttle/choke lever in front of the shifter. And under the top dash panel might be a hand written VIN number. But then those things still may only just validate the front of the car being real.
Lo-Fi Version | Time is now: 3rd May 2024 - 01:37 PM |
