Found 914/6 Value Help Please |
0396 |
Dec 10 2016, 08:54 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
8- 10k for a 914 6 engine is pretty optimistic...unless the buyer has the tub assigned from the factory for it.
But who knows,as the value is in the buyers mind. Good luck with journey |
Dec 10 2016, 09:37 AM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
8- 10k for a 914 6 engine is pretty optimistic...unless the buyer has the tub assigned from the factory for it. But who knows,as the value is in the buyers mind. Good luck with journey Just based what Ive personally sold those parts for in the past year. Your going to get $2,500 if the Webers are in good shape and $500 for the 914-6 specific air box. I sold a core 914-6 engine for $4k, a 914-6 trans for $2k. Then there is the engine mount, transmission shift rod, couple other mis 914-6 specific parts. Add in heat exchangers and exhaust. $10k easy. Remember, when you look at the unloved 914-6/ 2.0 T engine. The case sells for a grand, the crank another $1k. Rods, Heads, oil pump, p&c's chain boxes, cam towers, cams, distributor, fan, shroud, alternator, alternator shroud, fiberglass shroud, pressure plate, flywheel, ect. Start buying these pieces separately and they add up quickly. Many people still want the right size engine in their car. |
sixnotfour |
Dec 10 2016, 10:13 AM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I cant believe this hasn't come up
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) motor mount oil tank . dash. windshield tag, A B pillar tags Hoping the best for you when you get a better viewing (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/welcome.png) |
Kaeferfreund |
Dec 10 2016, 01:11 PM
Member Group: Members Posts: 122 Joined: 28-July 13 From: Germany Member No.: 16,172 Region Association: Germany |
Hi,
due to all the numbers (engine, trans) and spare parts you described, it sounds not so bad. I would also have a look at some other details, which I think most of the 914world "-6" experts answered here also know very well. Did you see into the engine bay? If possible look at the left side (oiltank etc.): It should not look like this side: |
0396 |
Dec 10 2016, 01:50 PM
8- 10k for a 914 6 engine is pretty optimistic...unless the buyer has the tub assigned from the factory for it. But who knows,as the value is in the buyers mind. Good luck with journey Just based what Ive personally sold those parts for in the past year. Your going to get $2,500 if the Webers are in good shape and $500 for the 914-6 specific air box. I sold a core 914-6 engine for $4k, a 914-6 trans for $2k. Then there is the engine mount, transmission shift rod, couple other mis 914-6 specific parts. Add in heat exchangers and exhaust. $10k easy. Remember, when you look at the unloved 914-6/ 2.0 T engine. The case sells for a grand, the crank another $1k. Rods, Heads, oil pump, p&c's chain boxes, cam towers, cams, distributor, fan, shroud, alternator, alternator shroud, fiberglass shroud, pressure plate, flywheel, ect. Start buying these pieces separately and they add up quickly. Many people still want the right size engine in their car. Yes, I agree with you if one takes that approach. I was simply thinking of a short block. |
forrestkhaag |
Dec 11 2016, 11:12 AM
I may have missed it in the myriad of responses but how about the bolt pattern on the wheels, the wheels, and more revealing the rear brake calipers / unique to 914's although, switchable...... (IMG:style_emoticons/default/beerchug.gif)
Karguy12 |
Dec 11 2016, 11:15 AM
Newbie Group: Members Posts: 10 Joined: 8-December 16 From: Florida Member No.: 20,656 Region Association: None |
I may have missed it in the myriad of responses but how about the bolt pattern on the wheels, the wheels, and more revealing the rear brake calipers / unique to 914's although, switchable...... (IMG:style_emoticons/default/beerchug.gif) It has complete 5 lug correct 914/6 suspension. The rear wheels are wider than factory. |
Larmo63 |
Dec 11 2016, 12:28 PM
Offer $12K and go up to 15k.
It would be pretty easy for most of us, and it might take 5 minutes to determine if this is a real /6. You need an expert to go with you. |
KELTY360 |
Dec 15 2016, 03:35 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
QUOTE About $8-10k. That's with all the parts you described. Based off what I've gotten for the same parts. Demand for a 911t engine might be lower than the later engines but there is still a demand. Just go on earlySreg. There is still good money moving around for these early engines. So based on this, if the car is NOT real, I've got about $10,000 in 914/6 parts (engine trans and suspension), and maybe $2,000-$4,000 in a parts car with the wheels? So around $12,000 conservatively? Another possibility is that it is a rear clipped car fixed from a rear end collision years ago. (that could be another explanation for the broken trans mounting arm) If that is the case, and there is a real 914/6 front clip, and a 914/4 rear clip with all of the 914/6 running gear, what does that make this frankenstein car worth? I will be able to inspect the body up on jacks next week. Any new developments? |
Unobtanium-inc |
Dec 15 2016, 04:53 PM
Advanced Member Group: Members Posts: 2,202 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
Always try to get a price or a range out of the seller before making an offer. You can save yourself a lot of hand wringing this way for three reasons.
1. If you ask for a range and says $75,000-100,000 because he saw an auction where one went for $150,000, then you can just walk away. 2. He might say a number that is very reasonable and then you just pay it. 3. If you make an offer and it's higher than what he thought the car was worth he might start thinking he doesn't know what the car is worth so he goes and does research and then his number and your number are out the window and his new price is full boat or higher. But when you do go to start talking $$$ bring cash so if you do strike a deal, then you can quickly do the deal, then call a tow truck and pay whatever it takes to get it away from there. Or bring a trailer. |
orthobiz |
Dec 16 2016, 04:56 AM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Another possibility is that it is a rear clipped car fixed from a rear end collision years ago. (that could be another explanation for the broken trans mounting arm) If that is the case, and there is a real 914/6 front clip, and a 914/4 rear clip with all of the 914/6 running gear, what does that make this frankenstein car worth? I will be able to inspect the body up on jacks next week. I rammed into someone in the 80's with my totaled 914 and the transmission mounts broke off... Paul |
Unobtanium-inc |
Dec 16 2016, 08:46 AM
Another possibility is that it is a rear clipped car fixed from a rear end collision years ago. (that could be another explanation for the broken trans mounting arm) If that is the case, and there is a real 914/6 front clip, and a 914/4 rear clip with all of the 914/6 running gear, what does that make this frankenstein car worth? I will be able to inspect the body up on jacks next week. I rammed into someone in the 80's with my totaled 914 and the transmission mounts broke off... Paul This 356A was hit very hard in the rear, it broke the ears off the gearbox. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:05 PM |
