Window adjustment, Search is not my friend |
JimN73 |
Dec 13 2016, 07:24 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
I'm having trouble adjusting the window in a late door.
Before I changed the delrin bushings, the front of the window didn't go quite to the top of the cap on the triangular window, there was a small gap between the window and the seal. Now that I've changed them, the gap has increased to 1/4 of an inch at the front, with a corresponding gap between the window and the seal. The back is OK. The top's fit is fine and te triangular window height is fine. I thought I could reposition the bracket that the roller rides in, but when I do - the roller pops off the bracket it's attached to. What adjustment am I missing? Thanks |
Mikey914 |
Dec 14 2016, 01:01 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes the search function is not as intuitive as you would like. However I did detail my install of the triangle window and some of the install manual on post 21
http://www.914world.com/bbs2/index.php?sho...window+seal+B.B I hope this is of help |
Lo-Fi Version | Time is now: 16th May 2024 - 05:28 PM |
