Installed a trickle charger jack port in wheel well, Don't have to open engine lid all the time |
oakdalecurtis |
Dec 14 2016, 05:40 PM
Oakdalecurtis Group: Members Posts: 1,324 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I've used a Noco trickle charger on my Optima Red Top battery in my 914 for many years whenever I'm parked in my garage. Sometimes with bad weather I don't drive the car a lot in the winter. I always open the engine lid and hook up the charger when I pull in the garage. I got tired of opening the engine lid every time and hooking up the charger jaws to the battery posts, and removing then charger and closing the engine lid every time I wanted to go for a drive. Open, close, open, close.....I finally made a 1/4 inch jack port holder under the rear wheel well and connected it with a wire lead to the battery positive. The negative is the jack grounded to the body by the steel jack holder bar. Now the charger hangs over the car, and when I go out , I just switch off the Noco charger, unplug the charging jack and hang the cord over the charger. When I return, in goes the jack and on goes the charger. I'm big on simple!
KELTY360 |
Dec 14 2016, 05:50 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Good idea to have the cord running past the driver's door so you can't forget to uplug on your way out.
ConeDodger |
Dec 14 2016, 06:26 PM
Apex killer! Group: Members Posts: 23,574 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Good idea to have the cord running past the driver's door so you can't forget to uplug on your way out. I have a shoreline on my company car that has a solenoid that kicks the cord out if I start the car without pulling it. I'd imagine McMaster Carr or Mouser would have something like that. Ask McMark. He's always innovating like that. |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:26 AM |
