Installed a trickle charger jack port in wheel well, Don't have to open engine lid all the time |
oakdalecurtis |
Dec 14 2016, 05:40 PM
Oakdalecurtis Group: Members Posts: 1,324 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I've used a Noco trickle charger on my Optima Red Top battery in my 914 for many years whenever I'm parked in my garage. Sometimes with bad weather I don't drive the car a lot in the winter. I always open the engine lid and hook up the charger when I pull in the garage. I got tired of opening the engine lid every time and hooking up the charger jaws to the battery posts, and removing then charger and closing the engine lid every time I wanted to go for a drive. Open, close, open, close.....I finally made a 1/4 inch jack port holder under the rear wheel well and connected it with a wire lead to the battery positive. The negative is the jack grounded to the body by the steel jack holder bar. Now the charger hangs over the car, and when I go out , I just switch off the Noco charger, unplug the charging jack and hang the cord over the charger. When I return, in goes the jack and on goes the charger. I'm big on simple!
boxsterfan |
Dec 15 2016, 09:11 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Driver's door gap looks off. Check your longs!! (IMG:style_emoticons/default/shades.gif)
Your trickle charger setup looks trick!! (IMG:style_emoticons/default/aktion035.gif) |
oakdalecurtis |
Dec 15 2016, 10:42 AM
Driver's door gap looks off. Check your longs!! (IMG:style_emoticons/default/shades.gif) Your trickle charger setup looks trick!! (IMG:style_emoticons/default/aktion035.gif) Thanks for the notice, but I just didn't have the door closed tightly. Here's a pic of my California kept dry car longs. |
boxsterfan |
Dec 15 2016, 02:15 PM
Driver's door gap looks off. Check your longs!! (IMG:style_emoticons/default/shades.gif) Your trickle charger setup looks trick!! (IMG:style_emoticons/default/aktion035.gif) Thanks for the notice, but I just didn't have the door closed tightly. Here's a pic of my California kept dry car longs. Yes, looking good!! Real good!!! Hopefully I will get to spend some time working on my teener over the Christmas break. Attached image(s) |
Lo-Fi Version | Time is now: 3rd May 2024 - 02:30 AM |
