Installed a trickle charger jack port in wheel well, Don't have to open engine lid all the time |
oakdalecurtis |
Dec 14 2016, 05:40 PM
Oakdalecurtis Group: Members Posts: 1,324 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I've used a Noco trickle charger on my Optima Red Top battery in my 914 for many years whenever I'm parked in my garage. Sometimes with bad weather I don't drive the car a lot in the winter. I always open the engine lid and hook up the charger when I pull in the garage. I got tired of opening the engine lid every time and hooking up the charger jaws to the battery posts, and removing then charger and closing the engine lid every time I wanted to go for a drive. Open, close, open, close.....I finally made a 1/4 inch jack port holder under the rear wheel well and connected it with a wire lead to the battery positive. The negative is the jack grounded to the body by the steel jack holder bar. Now the charger hangs over the car, and when I go out , I just switch off the Noco charger, unplug the charging jack and hang the cord over the charger. When I return, in goes the jack and on goes the charger. I'm big on simple!
PThompson509 |
Dec 19 2016, 01:15 PM
Member Group: Members Posts: 132 Joined: 9-August 05 From: Santa Cruz, CA Member No.: 4,564 Region Association: Northern California |
I've added a 110v plug to the side of my car - it has the auto-eject feature that was mentioned earlier in this thread. I've never gotten around to using it, though.
http://www.ev-propulsion.com/charging-accesories.html The reason I never did is that the plug is right near the driver-side door, so I can't get into the car without unplugging it. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 02:46 AM |
