Subaru Transmission Block Off Plates and Hydraulic Clutch Mount, Block-Offs $45, Hydraulic Clutch mounts $65 I have 10 of each! |
rnellums |
Dec 15 2016, 07:37 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I'm going to put another order in for some block off plates for the Subaru transmission conversions. It's a simple 1/8" laser cut aluminum plate with the holes in the right places. I will be putting in the order Monday, to take payment once they ship.
Dec 15 2016, 07:39 PM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Killer price. If I didn't have one already I'd be sending you money.
rnellums |
Dec 15 2016, 08:18 PM
turnaround89 |
Dec 15 2016, 09:17 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Ill take one!!!!! Let me know when you need payment.
BigFour1973 |
Dec 15 2016, 10:06 PM
Member Group: Members Posts: 187 Joined: 16-November 14 From: Long Beach Member No.: 18,126 Region Association: Southern California |
I'll take one. Please keep me posted on the cable shifter plate please.
JRust |
Dec 15 2016, 10:18 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Yes I am in for one! Thanks Ross
mgp4591 |
Dec 16 2016, 04:47 AM
914 Guru Group: Members Posts: 5,363 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I'll take one too - I'll eventually go to a manual because it's a sports car... and I can only be shiftless for so long.
Do you have any plans to market the clutch master bracket? Those look pretty trick! |
rnellums |
Dec 16 2016, 07:04 AM
I'll take one too - I'll eventually go to a manual because it's a sports car... and I can only be shiftless for so long. Do you have any plans to market the clutch master bracket? Those look pretty trick! I want to make sure the clutch brackets work as intended before I left them loose. But yes, probably here in a bit. |
jd74914 |
Dec 16 2016, 09:40 AM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Like I said in PM, I'm in for one too! Thanks Ross!
jimkelly |
Dec 16 2016, 02:52 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i'll take one please (IMG:style_emoticons/default/smile.gif)
rnellums |
Dec 27 2016, 10:16 AM
These were sent to the cutters last week, I'm hoping to hear back about them now that Christmas has past!
I also took some time to work on the next component, borrowing heavily from DBCooper! Attached thumbnail(s) |
Chris H. |
Dec 27 2016, 11:15 AM
Senior Member Group: Members Posts: 4,027 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Great idea. Love it. That will be very sturdy and make it easy to adjust the cables. Another thought for you...reasonably priced trans level indicator (see-thru glass or plexi). You could put it in the block off plate or make one similar to the SubaruGears one. Block-off plate location would be more accurate and easier to read (and cheaper for us CSOBs).
Maybe thread it to fit one of these at the correct level: Site glass bolt |
rnellums |
Dec 28 2016, 08:31 AM
Great idea. Love it. That will be very sturdy and make it easy to adjust the cables. Another thought for you...reasonably priced trans level indicator (see-thru glass or plexi). You could put it in the block off plate or make one similar to the SubaruGears one. Block-off plate location would be more accurate and easier to read (and cheaper for us CSOBs). Maybe thread it to fit one of these at the correct level: Site glass bolt I like the idea of a sight glass! But why not just use the dipstick? |
Chris H. |
Dec 28 2016, 09:09 AM
Because the level is not accurate sometimes with the dipstick since the trans is pointing slightly downward in the stock Subaru setup. Many conversion people have theirs level or tail end just a bit up like a 914's. In those cases you need more oil than the stick would indicate to cover the uphill section since it's calibrated for stock. If there's not enough gear oil it can cause a whine and premature wear of the higher gears. Mostly it's just that you wouldn't have to worry about it. Is there too much? Not enough? Is it dirty? Should I change it? Probably fine 99% of the time but for what...$25 extra you could see the level? I'd have that.
rnellums |
Jan 16 2017, 09:55 PM
Finally got the endplates back. I also made a few more of the hydraulic clutch mounts, and the first prototype of a shifter cable bracket.
mgp4591 |
Jan 17 2017, 01:00 AM
I like where this is going... (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/popcorn[1].gif)
turnaround89 |
Jan 17 2017, 09:55 PM
Sign me up for the hydraulic clutch mount as well as the backing plate. What kind of master cylinder is that for the clutch?
turbonet |
Jan 17 2017, 11:53 PM
Member Group: Members Posts: 68 Joined: 14-September 16 From: Vancouver Member No.: 20,398 Region Association: Canada |
Any block off plates available still??
rnellums |
Jan 18 2017, 07:13 AM
jd74914 |
Jan 18 2017, 08:00 AM
How much are the clutch master brackets Ross? I'd be in for one pending price.
Lo-Fi Version | Time is now: 20th April 2024 - 03:19 AM |
