needing to find a washer, crush washer under oil relief piston |
brant |
Dec 16 2016, 12:24 PM
I want to replace the large crush washer under the plug for the oil relief piston
I can't find it on pelican does anyone know the part number, or size, or just a resource to get this washer? I wasn't able to find the part diagrams I used to use on pelican and wasn't able to track down this crush washer with their search Here is stolen google image (not my car) of the one I'm looking for: thanks in advance brant Attached image(s) |
StratPlayer |
Dec 16 2016, 12:32 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Keith914 |
Dec 16 2016, 12:54 PM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
I just installed a copper washer that looks just like this, --no more leak. |
stugray |
Dec 16 2016, 01:05 PM
Brant,
Last time I needed one I ordered them from PP, but it took months to get in. I ordered extras, so if you want to stop by tonight or this weekend, I can find them and give you one. In a pinch, you can clean up any burrs and reuse them, but mine seeped very slowly after I did that last time. |
brant |
Dec 16 2016, 01:43 PM
awesome thank you I want to get measurements tonight.. that one still appears small? but hard to guess without a measurement. I can call them and figure it out thanks a ton!!!! |
brant |
Dec 16 2016, 01:46 PM
Brant, Last time I needed one I ordered them from PP, but it took months to get in. I ordered extras, so if you want to stop by tonight or this weekend, I can find them and give you one. In a pinch, you can clean up any burrs and reuse them, but mine seeped very slowly after I did that last time. NICE OFFER! I re used my old one last night I added yama-bond (Honda bond actually)... it will probably not leak that stuff is awesome but like you I had a slow seep after reusing in the past I thought I had one in my stash. couldn't find it last night any chance you have the part number on the bag of your spares? thanks again for the offer I hope it doesn't take months and months but I think the Honda bond will likely do the trick for now at least I'll leave it and try when I add oil this weekend. just need to get a spare on hand for next time. brant |
Chris H. |
Dec 16 2016, 01:52 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Look in the 914 section. There's a much larger one. I have a bunch of copper washers...somewhere...if you don't find the size you need. Post the size and I will check my stash.
Mikey914 |
Dec 16 2016, 02:35 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Guys if these are difficult to get, I'll order in a crap ton and put them on the site to make it faster to get. Just let me know your experience. We can always machine it it you can't easily get. I suspect they are readily available, but I've been wrong before.
Keith914 |
Dec 16 2016, 02:42 PM
I got a copper washer from European Motorworks. Washer looked a bit thin, but probably so to squash it more easily given the straight screw driver style fastening compromise.
brant |
Dec 16 2016, 02:54 PM
For future reference:
It looks like the size is: 22 x 29 Porsche part number (from PET) N 013 829 3 and the sierra madre link to a good price:crush washer I found them on pelican with that part number an original OEM part, from Germany at $2.50/each I'm waiting to hear back if they are now in stock... or if like Stu experienced... it will take way to long to get I have found some generic ones on the internet of the same size, mostly copper. I would think copper would work great, but I've emailed pelican and waiting to hear back on the original aluminum version. |
914Sixer |
Dec 17 2016, 08:01 AM
Copper will work just fine. The OEM ones were aluminum to keep the cost down.
bdstone914 |
Dec 17 2016, 08:48 AM
Copper will work just fine. The OEM ones were aluminum to keep the cost down. McMasterCarr has them too in packs of 10 https://www.mcmaster.com/#standard-crush-washers/=15iaz0i |
0396 |
Dec 17 2016, 09:03 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Copper will work just fine. The OEM ones were aluminum to keep the cost down. McMasterCarr has them too in packs of 10 https://www.mcmaster.com/#standard-crush-washers/=15iaz0i As usual, Bruce sharing his wealth of knowledge (IMG:style_emoticons/default/pray.gif) Packs of 10..for all those engine builds. (IMG:style_emoticons/default/biggrin.gif) |
stugray |
Dec 17 2016, 11:26 AM
The OEM are aluminum hollow crush washers.
I have tried the basic Aluminum solid washers and they dont seal as well. Here is a pic of both: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1481995594.1.jpg) So Brant, Even if you order some more (and they take a long time to receive), you can come by and get one from me now and just replace it later. I am in the middle of rebuilding my engine now so I will be needing just one in a week or so. (I currently have three new). I also have 8 of the solid washers. |
TheCabinetmaker |
Dec 17 2016, 12:20 PM
Mine leaked with both new copper and aluminum crush washers. More than once. I ditched the washer and made a paper gasket and used gaskacinch on both sides. No more leaks
brant |
Dec 17 2016, 12:23 PM
Agreed
The crush design is much more effective at the low torque the factory wanted (Likely the reason it is a slotted fastener and not a bolt head) Why are you rebuilding your motor? What happened? |
stugray |
Dec 17 2016, 12:50 PM
Agreed The crush design is much more effective at the low torque the factory wanted (Likely the reason it is a slotted fastener and not a bolt head) Why are you rebuilding your motor? What happened? I was hearing a noise that sounded like an exhaust leak right at 6200 RPM in the very last race of the year at PPIR. When I got the car home I could not find an obvious source of an exhaust leak and a compression test showed less than 80 PSI on all 4 cylinders. My next suspicion was a head leak because I dont use head gaskets. So I pulled the engine to have a look. I DID find evidence of exhaust leaks at the header stubs and at the head copper gaskets. I did NOT find any evidence of a head leak. What I DID find was that one of my OEM Sodium filled exhaust valves looked to be failing. I had yellow coloration on that valve and in the exhaust stub for one cylinder only. So I had a valve job to replace the exhaust valves with SS and upgraded to dual springs to bring my max RPMs up. The rest of the engine looks perfect inside so I wont even crack the case. I will hone the cylinders, replace the rings, and put it back together. |
porschetub |
Dec 17 2016, 02:08 PM
[quote name='brant' date='Dec 18 2016, 07:23 AM' post='2434846']
Agreed The crush design is much more effective at the low torque the factory wanted (Likely the reason it is a slotted fastener and not a bolt head) The crush washers do work better as mentioned and considered to be single use only,modern car sump bung washers are one use also....ask my Audi service guys why (IMG:style_emoticons/default/sad.gif) . |
bdstone914 |
Dec 17 2016, 07:30 PM
Lo-Fi Version | Time is now: 16th May 2024 - 03:24 PM |
