914 Engine Test Stand |
motomoss |
Dec 16 2016, 12:33 PM
Newbie Group: Members Posts: 4 Joined: 1-July 12 From: New Buffalo MI Member No.: 14,620 Region Association: None |
This is a custom made engine test stand specifically for a 914 motor. Uses stock engine and trans mounting locations. Engine support brace included as shown in photos. Motor drops in from above with plenty of clearance for exhaust either stock or headers. Switch board is wired to run pumps for fuel injection or carburetor. All wires are labeled and go to stock engine terminals. Very sturdy, roll-able, and built at a nice height for test run and tune. Battery shown not included. Getting out of 914's, so no longer need it. Item is located in Southwest MI, close to Chicago. Asking price is $550. Click links below for more photos and video.
Please send PM if interested. Video of test stand in use (before being epoxy coated) Click here for video More Photos Click Here Attached thumbnail(s) |
motomoss |
Dec 16 2016, 12:51 PM
test
N_Jay |
Dec 16 2016, 01:46 PM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
Dies it have a connection for the stock engine harness, or do you have to connect each circuit separately?
euro911 |
Dec 16 2016, 02:10 PM
Very nice.
JOEPROPER |
Dec 16 2016, 02:18 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Doesn't look like you can take it apart for shipping purposes... Very nice none-the -less. Looks like an easy way to set up an engine. The work is already done. Nice.
JOEPROPER |
Dec 16 2016, 02:20 PM
Actually, you could cut it in half and weld it back together or bolt it together pretty easily. PM coming.
motomoss |
Dec 16 2016, 02:45 PM
Dies it have a connection for the stock engine harness, or do you have to connect each circuit separately? Its not set up at this point to plug in the stock brain box. You would have to provide your own brain box and relay board, but power is there and could be easily wired to the back of the switch panel. |
N_Jay |
Dec 16 2016, 03:42 PM
Dies it have a connection for the stock engine harness, or do you have to connect each circuit separately? Its not set up at this point to plug in the stock brain box. You would have to provide your own brain box and relay board, but power is there and could be easily wired to the back of the switch panel. I wasn't thinking so much of the FI harness as much as the main harness, starter connections and Alt connections. |
motomoss |
Dec 17 2016, 10:37 PM
Sold,
Thanks Garold |
Lo-Fi Version | Time is now: 16th May 2024 - 12:20 PM |
