914 stock camshaft question |
adidas |
Dec 17 2016, 11:16 AM
Member Group: Members Posts: 489 Joined: 6-February 03 From: Charlotte NC Member No.: 250 |
Does anyone know the duration and lift specs on the camshaft on a stock 2.0 engine? The stock camshaft that was installed from the factory on fuel injected engines.
larryM |
Dec 17 2016, 02:20 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
per "914 Technical Specs" book Porsche #4222.21 1st edn, May 1,1974
"valve timing with 1mm valve clearance I opens 12 BTDC I closes 42 ATDC E opens 43 BBDC E closes 4 ATDC" you should be able to calculate duration from that Does anyone know the duration and lift specs on the camshaft on a stock 2.0 engine? |
Lo-Fi Version | Time is now: 16th May 2024 - 04:10 PM |
