FS: OEM sideshift conversion kit |
Carquip |
Dec 22 2016, 01:59 PM
I'm new here ... Group: Members Posts: 0 Joined: 22-December 16 From: Boulder, CO Member No.: 20,689 Region Association: None |
Hey there fellow 914ers! OEM Porsche parts to make your early 914 tailshifter into the 73 and later sideshifter. From the shift stick to the tailcone, only one item missing is the firewall bushing. All components are OEM parts and full instructions are included. We also recommend a trans gasket set ( also available ). $1495.00 for the kit
Also if you need any other parts such as syncros or seals we stock them all at shop discounted prices. email@carquip.com or call 303-443-1343 Thanks!! |
bdstone914 |
Dec 22 2016, 02:18 PM
Is the conversion bushing for the firewall included?
bdstone914 |
Dec 22 2016, 02:19 PM
Those are not all the parts needed.
Missing several parts. At least 9 needed parts that are not in your picture. And you show the firewall boot in the picture which you say is not there. So it is not included? |
Carquip |
Dec 22 2016, 03:40 PM
Those are not all the parts needed. Missing several parts. At least 9 needed parts that are not in your picture. And you show the firewall boot in the picture which you say is not there. So it is not included? What 9 parts are you talking about? We do not want to be selling a incomplete kits. To my knowledge this was all needed. |
Carquip |
Dec 22 2016, 03:43 PM
Those are not all the parts needed. Missing several parts. At least 9 needed parts that are not in your picture. And you show the firewall boot in the picture which you say is not there. So it is not included? Firewall boot included, changed ad stating that firewall conversion bushing is missing. Thanks for pointing it out. |
bdstone914 |
Dec 22 2016, 11:09 PM
[/quote] Engine cross bar -side shift type. Engine to motor mount brackets (2) Motor mounts (2) Engine bar to body brackets (2) Hardware for the above Drivers side warm air guide. Different than tail shift. Cup at end of rear shift bar Firewall conversion bushing. The 914 424 224 03 firewall bushing is for the tail shift. Larger inside diameter. |
Carquip |
Dec 23 2016, 12:28 PM
[quote name='bdstone914' date='Dec 23 2016, 12:09 AM' post='2436648']
What 9 parts are you talking about? We do not want to be selling a incomplete kits. To my knowledge this was all needed. [/quote] Engine cross bar -side shift type. Engine to motor mount brackets (2) Motor mounts (2) Engine bar to body brackets (2) Hardware for the above Drivers side warm air guide. Different than tail shift. Cup at end of rear shift bar Firewall conversion bushing. The 914 424 224 03 firewall bushing is for the tail shift. Larger inside diameter. [/quote] Thank you very much! We will get the parts together asap. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:16 AM |
