PMB's method of brake bleeding |
tomh |
Jan 6 2017, 09:47 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
PMB has a tech tip on "gravity bleeding" your brakes. What it doesn't explain is the way to bleed a caliper with 2 bleeders.
Did I miss something or do just use only one of the bleeder ports. |
bandjoey |
Jan 8 2017, 12:12 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
How do you use speed bleeders with one person. ?
GregAmy |
Jan 8 2017, 08:38 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
How do you use speed bleeders with one person. ? They have an internal check valve. Air and fluid goes out, but the check valve keeps air from coming back in. So you hook up the bottle, crack the bleeder quarter turn, then jump in the car and slowly cycle the brake pedal. I used to use them on the race and street cars, but had limited success. I found that unless I put some kind of sealant on the threads (Teflon paste, for example) then air could get sucked in past the threads. In the end it's just easier for me to nicely ask the wife to work the pedal while I work the bleeders (plus it's a good excuse to take her out to dinner after at my fav gastropub). |
Lo-Fi Version | Time is now: 17th May 2024 - 08:36 PM |
