Fat 1.7-2.0 P/C, What should I expect to pay? |
Malmz |
Jun 27 2003, 03:33 PM
CSOBOSC founding member Group: Benefactors Posts: 489 Joined: 22-April 03 From: So. Cal Member No.: 602 |
Ok, looks like I need 1 P/C for the motor I just dropped. It was build by Fat. It is a 1.7 built to a 2.0.
How much should I expect? Should I get it from Fat, or elsewhere? Any tips on identifying or anything else to do? Everything else in the motor looks good, #1 is just jacked. Still trying to mentally recreate exactly what happened to it. Exhaust valve on #1 was too tight Head stud bolt over #1 and too the back was loose Piston lost material which has been redeposited on the head and everywhere else Piston is waaaay wasted Cylinder is worked because of wasted piston #2 P/C looks good, still has cross hatch, etc. sm |
aufaber |
Jun 27 2003, 04:31 PM
Member Group: Members Posts: 190 Joined: 7-April 03 From: Huntington Beach, CA Member No.: 525 |
You could call and ask: (IMG:style_emoticons/default/unsure.gif) http://www.fatperformance.com/index.htm
714.637.7352 (IMG:style_emoticons/default/huh.gif) -AaroN G> |
Malmz |
Jun 27 2003, 06:35 PM
Been talking to the guy at Fat and we have been trying to identify exactly what P/C are in this thing.
We have determined they are 96mm pistons and the crank is 71mm. They are flat top pistons with absolutely no valve reliefs in them. I need to get a better clip removal tool, been fighting the pin clip with mine and haven't been able to get the piston off yet. The guy at Fat says getting a single P/C may be tough, but I'm still optimistic. Sound familar to anybody, or does anyone have a single that sounds the same? Anyone want to buy a track car!!! $5k as is!!! http://www.malmz.com/cars/914_240/index.htm It's not mine, but it is here. sm |
Malmz |
Jun 27 2003, 08:36 PM
Got the piston off. Can anyone ID it? Where's Brad!!! (IMG:style_emoticons/default/ohmy.gif)
Malmz |
Another one. TS marking.
Malmz |
Jun 27 2003, 08:37 PM
Now for the reaaaaalllllyyyyy ugly stuff...
Malmz |
Guess I need to clean my desk...
MarkV |
Jun 27 2003, 10:12 PM
You might try these guys. I contacted them last week. They sell 96 x 71 "Keith Black" flat top P&C's for $349.00. Brad says they are decent parts. They are made in China. (IMG:style_emoticons/default/idea.gif)
European Motor Works |
Lo-Fi Version | Time is now: 12th May 2024 - 02:10 PM |
