What is the bolt size for Center Seat Belts |
Mike Fitton |
Jan 14 2017, 05:48 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
Have a set of center seat belts for the middle 3rd seat, had to drill out the plastic phillips head screws that were installed by the factory in the threaded anchor holes. They look smaller than the standard holes for the driver and passenger belts does anyone know what size bolts these take?
Mike Bellis |
Jan 14 2017, 09:14 PM
All seat belts in the US use a 7/16-20 thread. Or at lease most of them...
SirAndy |
Jan 14 2017, 11:01 PM
Resident German Group: Admin Posts: 41,608 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
They look smaller than the standard holes for the driver and passenger belts does anyone know what size bolts these take? Pretty sure they are the same as the normal seat belts ... (IMG:style_emoticons/default/smile.gif) |
Mike Fitton |
Jan 15 2017, 09:25 AM
Ok that is what I thought, I am going to tackle it again today, maybe didn't get all the plastic screw remnants out. I'll use a heat gun on it.
Mike Fitton |
Jan 17 2017, 09:30 PM
Yep plastic sleeve was still stuck to the threads heat gun took care of that, same size bolt works. Thanks!
Lo-Fi Version | Time is now: 1st May 2024 - 03:25 AM |
