Rear Wheel Bearing Difference, Comparison that may have caused my failures |
914Sixer |
Jan 15 2017, 03:50 PM
For months now I have maintained there is a big difference in the quality of the new rear bearings verses the original ones. Today I had time to compare an original FAG (Germany)and a new SKF (Italy) bearing shells. MY conclusion is what I suspected, the new ones are NOT the same. I took pictures and measurements to document what I saw. I hope the pictures let you see the difference. Guess which one is the original German one!
Attached image(s) |
Krieger |
Jan 15 2017, 06:35 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I am new to this discussion, but may be a victim. There is an obvious visual and measurable difference in the two parts your measuring, but overall don't they go by OD/ID and some sort of load rating? I had heard that these are the same bearings they use in Boxster. If so, is the bearing held in the same way?
Lo-Fi Version | Time is now: 17th May 2024 - 01:36 AM |
