Rear Wheel Bearing Difference, Comparison that may have caused my failures |
914Sixer |
Jan 15 2017, 03:50 PM
For months now I have maintained there is a big difference in the quality of the new rear bearings verses the original ones. Today I had time to compare an original FAG (Germany)and a new SKF (Italy) bearing shells. MY conclusion is what I suspected, the new ones are NOT the same. I took pictures and measurements to document what I saw. I hope the pictures let you see the difference. Guess which one is the original German one!
Attached image(s) |
914Sixer |
Jan 15 2017, 09:57 PM
Yes, the Boxster bearing is the same item. The SKF was factory greased when I installed it. The FAG had smaller bearings than the SKF. Not sure if that made any difference.
Lo-Fi Version | Time is now: 17th May 2024 - 02:16 AM |
