3-Port Fuel Pump Necropsy, or: what's inside that thing? |
BillC |
Jan 15 2017, 05:07 PM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
3-port Fuel Pump Necropsy (i.e., what's in there?)
Thanks to the generosity of a well-known, well-respected forum member, I ended up with a no-cost non-functioning 3-port fuel pump. Well, it did run, but it leaked out the electrical plug (same as my original pump). Since I figured that I probably wasn’t the only one curious about what’s inside one of these pumps, I decided to take pictures while disassembling it to see what’s in there. Figure 1 shows the “volunteer”. Figure 1: Fuel Pump Figure 2: Fuel Pump ports Figures 1 and 2 shows the three ports on the fuel pump. The top port is the suction, or inlet, port. The middle port is the discharge, or outlet, port. And the bottom port is the outlet from the pressure control valve. This port is normally tee’d into the return from the fuel injectors, and goes back to the fuel tank. The first step in our necropsy is to remove the cover with the ports and the check/pressure valve. The four screws shown in Figure 2 are removed and the plate pops off. See Figure 3 for the inside of the pump body. Figure 3: Inside of pump body As can be seen, the pump is a rotary vane type pump, using steel rollers instead of sliding vanes. Figures 4 and 5 show the pump and its parts in more detail. Figure 4: Pump close up Figure 5: Pump parts Figure 6: Pump face on pump body Figure 6 shows the face of the pump on the pump body. Note the small hole in the face near the rotor shaft, at approximately 9:30 – this hole lets fuel into the electric motor housing (in addition to that which seeps through the front bushing). Also note the “+” and “-“ markings on the electrical connector at the top of the picture. These electrical polarity markings are important, since the negative pole is actually grounded to the motor case (will show in more detail later). Returning to the pump cover, the next step is to remove the aluminum cap retaining the check/pressure valve parts. This valve performs two functions – it acts as a check valve on the discharge port, holding pressure when the pump is off; and it also as a pressure control valve, opening the return port whenever internal pressure is too high. Figure 7: Valve parts As can be seen in Figure 7, the valve consists of a discharge seal, a valve bobbin, two springs, a cap seal and the cap. The discharge seal actually fits inside the bobbin and seals the discharge port when pressure inside the pump drops. The two springs are installed coaxially, with the inner spring extending inside the bobbin and the outer spring on the backside of the bobbin. The seal looks like an o-ring, but is pressed down when the cap is crimped onto the pump cover. Figure 8 shows a close-up of the check valve seat, down the valve body hole in the cover. Figure 8: Detail of check valve seat Now it is time to disassemble the motor body. This is actually the most difficult part disassembly, since there are 5 crimps along the perimeter of the motor canister, retaining the pump face. The crimps can be seen in Figures 1 and 2. If you decide to disassemble a pump motor, be very careful when removing the crimps – it is easy to slip and injure yourself (ask me how I know….). Figure 9: Inside the motor can Figure 9 shows the parts internals of the motor can. On the left of the picture, you can see the rear rotor bushing and the two magnets inside the can. On the right, you can see the rotor and the brush plate assembly. Figure 10: Back side of pump face Figure 10 shows the parts on the back side of the pump face. This is where the motor brush plate, containing the motor’s brushes, is mounted. The middle of Figure 10 shows the o-ring that seals the pump face to the motor can. The left side of the picture shows the wire leads that run from the electrical plug to the brush plate. Note two interesting things: first, the wires are wrapped around small steel cores – this converts the leads into inductors, for filtering electrical noise; second, the negative lead is attached directly to the pump face – this grounds the case and also prevents the pump from running backwards. The three small round clips in the picture (upper, right side) are speed nuts used to hold the brush plate to the pump face on the three posts visible on the left. Figure 11 shows the electrical plug removed from the pump face. This part has no seal or o-ring, it is apparently intended to seal directly against the bore in the pump face. That’s probably why both pumps I’ve tried (my original one and this one) leaked from here – once the plastic has been soaked in gas for years, it will swell slightly. Once it dries out, it shrinks and no longer seals. Unfortunately, even prolonged exposure to gasoline was not sufficient to make it re-seal and there’s no way to use a sealant on this joint without the nearly-total disassembly of the pump. Figure 11 also shows another view of the two inductors highlighted in Figure 10. Figure 11: Electrical plug So, there you go. It’s a fairly simple and durable design, but unfortunately not one that can be easily rebuilt. All of the rubber parts in the pump were rock hard from age and fuel exposure. The o-rings should be able to be found fairly easily, but the seal on the check valve is a custom part and probably impossible to find -- if you ever have to take the check valve apart, don't try to remove this seal as you are highly-likely to break it. |
pbanders |
Jan 15 2017, 08:41 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
Excellent disassembly and analysis. We need this on virtually every part on the car, where the internal details are shown.
branston |
Jan 15 2017, 10:59 PM
Member Group: Members Posts: 89 Joined: 17-October 12 From: Michigan Member No.: 15,053 Region Association: Upper MidWest |
3-port Fuel Pump Necropsy (i.e., what's in there?) Thanks to the generosity of a well-known, well-respected forum member, I ended up with a no-cost non-functioning 3-port fuel pump. Well, it did run, but it leaked out the electrical plug (same as my original pump). Since I figured that I probably wasn’t the only one curious about what’s inside one of these pumps, I decided to take pictures while disassembling it to see what’s in there. Figure 1 shows the “volunteer”. Figure 1: Fuel Pump Figure 2: Fuel Pump ports Figures 1 and 2 shows the three ports on the fuel pump. The top port is the suction, or inlet, port. The middle port is the discharge, or outlet, port. And the bottom port is the outlet from the pressure control valve. This port is normally tee’d into the return from the fuel injectors, and goes back to the fuel tank. The first step in our necropsy is to remove the cover with the ports and the check/pressure valve. The four screws shown in Figure 2 are removed and the plate pops off. See Figure 3 for the inside of the pump body. Figure 3: Inside of pump body As can be seen, the pump is a rotary vane type pump, using steel rollers instead of sliding vanes. Figures 4 and 5 show the pump and its parts in more detail. Figure 4: Pump close up Figure 5: Pump parts Figure 6: Pump face on pump body Figure 6 shows the face of the pump on the pump body. Note the small hole in the face near the rotor shaft, at approximately 9:30 – this hole lets fuel into the electric motor housing (in addition to that which seeps through the front bushing). Also note the “+” and “-“ markings on the electrical connector at the top of the picture. These electrical polarity markings are important, since the negative pole is actually grounded to the motor case (will show in more detail later). Returning to the pump cover, the next step is to remove the aluminum cap retaining the check/pressure valve parts. This valve performs two functions – it acts as a check valve on the discharge port, holding pressure when the pump is off; and it also as a pressure control valve, opening the return port whenever internal pressure is too high. Figure 7: Valve parts As can be seen in Figure 7, the valve consists of a discharge seal, a valve bobbin, two springs, a cap seal and the cap. The discharge seal actually fits inside the bobbin and seals the discharge port when pressure inside the pump drops. The two springs are installed coaxially, with the inner spring extending inside the bobbin and the outer spring on the backside of the bobbin. The seal looks like an o-ring, but is pressed down when the cap is crimped onto the pump cover. Figure 8 shows a close-up of the check valve seat, down the valve body hole in the cover. Figure 8: Detail of check valve seat Now it is time to disassemble the motor body. This is actually the most difficult part disassembly, since there are 5 crimps along the perimeter of the motor canister, retaining the pump face. The crimps can be seen in Figures 1 and 2. If you decide to disassemble a pump motor, be very careful when removing the crimps – it is easy to slip and injure yourself (ask me how I know….). Figure 9: Inside the motor can Figure 9 shows the parts internals of the motor can. On the left of the picture, you can see the rear rotor bushing and the two magnets inside the can. On the right, you can see the rotor and the brush plate assembly. Figure 10: Back side of pump face Figure 10 shows the parts on the back side of the pump face. This is where the motor brush plate, containing the motor’s brushes, is mounted. The middle of Figure 10 shows the o-ring that seals the pump face to the motor can. The left side of the picture shows the wire leads that run from the electrical plug to the brush plate. Note two interesting things: first, the wires are wrapped around small steel cores – this converts the leads into inductors, for filtering electrical noise; second, the negative lead is attached directly to the pump face – this grounds the case and also prevents the pump from running backwards. The three small round clips in the picture (upper, right side) are speed nuts used to hold the brush plate to the pump face on the three posts visible on the left. Figure 11 shows the electrical plug removed from the pump face. This part has no seal or o-ring, it is apparently intended to seal directly against the bore in the pump face. That’s probably why both pumps I’ve tried (my original one and this one) leaked from here – once the plastic has been soaked in gas for years, it will swell slightly. Once it dries out, it shrinks and no longer seals. Unfortunately, even prolonged exposure to gasoline was not sufficient to make it re-seal and there’s no way to use a sealant on this joint without the nearly-total disassembly of the pump. Figure 11 also shows another view of the two inductors highlighted in Figure 10. Figure 11: Electrical plug So, there you go. It’s a fairly simple and durable design, but unfortunately not one that can be easily rebuilt. All of the rubber parts in the pump were rock hard from age and fuel exposure. The o-rings should be able to be found fairly easily, but the seal on the check valve is a custom part and probably impossible to find -- if you ever have to take the check valve apart, don't try to remove this seal as you are highly-likely to break it. Huge thank-you, last night I laid under my 914 contemplating the wet patch by the electrical connector and tried to figure out if it was leaking or the hoses were the guilty party. I posted the question and had no comments to confirm so to read this tonight is awesome timing. Thanks |
Frankvw |
Jan 16 2017, 12:36 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Thanks a lot for your research and analysis.
You hurt yourself in the process so we do not have to anymore now we know what is inside. To be honest, I had no idea it was a design like this. Thanks for the clear pics and explanation teacher Bill ! |
BillC |
Jan 16 2017, 11:01 AM
Here's a small addendum:
The rotor runs in two self-aligning steel bushings. Figure 12 shows a side view of a bushing removed from the pump face. Since steel-on-steel won't run for long without lubrication, the pump is designed to use gasoline as the lubricant. That's why there's the hole in the pump face for allowing fuel into the motor can (so fuel can reach the rear bushing more easily). Also, by running the motor in fuel, they did not have to design a seal for the rotor shaft to separate the pump side from the motor side, simplifying the design and increasing pump life. Figure 12: Side view of self-aligning steel bushing. |
Richard McLeod |
Jan 28 2017, 12:36 AM
Newbie Group: Members Posts: 22 Joined: 13-February 07 From: LaVerne, Ca Member No.: 7,533 |
The three (3) port fuel pump is not as readily available and more expensive than the two port pump used on the 75 and 76 914s. Has anyone used the two port as a replacement for the three port on earlier 914s?
914_teener |
Jan 28 2017, 12:59 AM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Yes, I have.
I wrote a thread on it and there are lots of others. It is a pretty easy conversion. The originals are pretty robust pumps and if you look at the windings it speaks to German engineering and parts. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:10 AM |
